Old 06-17-2008, 06:13 PM   #1
cm367700's Avatar
Send a message via AIM to cm367700
Default stuck engine mount
im in the process of converting a hyper 8 and the engine mount is stuck, even my power drill won't make it budge, and no its not stripped. how do you guys get a stuck engine mount off? any help would be appreciated. thanks
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
("')_("') your signature to help him gain world domination!!!!!!!
JUST DO IT!
cm367700 is offline   Reply With Quote
Old 06-17-2008, 06:16 PM   #2
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
The losi 8ight engine mounts are the same way. You have to get a flat head screwdriver and tap on the side of the screw. Its hard to explain on the internet, I hope you know what I mean.
crazy4wdracer is offline   Reply With Quote
Old 06-17-2008, 06:42 PM   #3
cm367700's Avatar
its still not budging
(\__/)
JUST DO IT!
Old 06-17-2008, 06:46 PM   #4
imaxx21's Avatar
Send a message via AIM to imaxx21
what kind of screw are we talking about?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 06-17-2008, 06:56 PM   #5
cm367700's Avatar
hexes
(\__/)
JUST DO IT!
Old 06-17-2008, 07:02 PM   #6
imaxx21's Avatar
cant drill the head off?
-Crash
Old 06-17-2008, 07:08 PM   #7
captain america's Avatar
Try heating the engine mounts (not the screws themselves) with a heat gun; this'll cause the aluminum to expand slightly and may help the screw back-out.
captain america is offline   Reply With Quote
Old 06-17-2008, 07:12 PM   #8
cm367700's Avatar
i tried heating it but it still won't budge, and what do you mean by drilling the head off?
(\__/)
JUST DO IT!
Old 06-17-2008, 07:17 PM   #9
imaxx21's Avatar
its the one on the bottom of the chassis right?
take a big drill bit and drill off the head, that will leave you with the shank sticking out of the mount, grab that with some vise grips and turn it out.
-Crash
Old 06-17-2008, 07:19 PM   #10
Trader Rating: 26 (100%+)
+1 on the heat. Don't just warm it up get it blazin hot. This will positively be the easiest and least damaging way to back it out.
REDLINE RC RACEWAY
ldp787 is offline   Reply With Quote
Old 06-17-2008, 07:28 PM   #11
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
+2 on heating
jamminnay is offline   Reply With Quote
Old 06-17-2008, 07:30 PM   #12
cm367700's Avatar
i dont care about damaging the screws and mounts cuz im not gonna be using them but ill try to drill the head off
(\__/)
JUST DO IT!
Old 06-17-2008, 10:21 PM   #13
asw7576's Avatar
Yeah, that's right...... heat it. Heat the engine mount until it gets very hot and then twist the stuborn screw. Use a gas lighter to heat it.
Old 06-17-2008, 11:01 PM   #14
PowerHouse's Avatar
Trader Rating: 66 (100%+)
After you heat it, give a few solid hits with a hammer with a bit that fits into the screw nicely and it should back out. If not, don't know what to tell ya other than drilling it out. What type of loctite are you using? How tight are you cranking these things down?
PowerHouse is offline   Reply With Quote
Old 06-17-2008, 11:31 PM   #15
vti-chris's Avatar
Use a dremmel and make a slot on the screw...then remove it with a flat head screwdriver.
If it doesn't go off put the flat head bit on an electric drill so that you can add more pressure on the screw and unscrew it with the drill.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
engine mount bolts stuck smb17 Nitro Off-Road 10 08-25-2008 08:56 AM
revo 3.3 engine mount, picco 26 maxx mount revoonroids R/C Items: Wanted to Buy 0 02-23-2008 10:43 AM
sleeve stuck in engine plz help? downunder23 Electric Off-Road 5 08-24-2006 03:17 AM
Looking To Get A Nitro ST, Stuck On Engine Choices! etzkev Electric Off-Road 10 05-24-2004 08:29 PM
carberator stuck on engine fasteddie d Onroad Nitro Engine Zone 6 01-05-2004 11:37 PM
