Old 06-17-2008, 05:27 AM   #1
Default Clutch Bearing Maintenance
Hi all,
I have just got a new lot of clutch bearings (10pk) and some ceramic ones as well.. I tried the ceramic ones and they dried up real quick after just 1 run at the park, they are still real smooth just dry
I am going to clean them all out and use a better lube as i think they have been either under lubed or sh1tty lube has been used...
what is better, using bearing oil or bearing grease?
I know the grease will last longer at the cost of more friction but i thought it might be better for clutch bearings...
If i use bearing oil, will the oil last the life of the bearings or will i need to oil them more than once? i am going to change them about every half gallon or so.
What type of oil do i need for the bearings?
til now i have been use a PFTE grease made by innox but its hard to get in these tiny bearings.
also how do you guys oil you bearings? just pop off the nylon shield and add a couple drops after i have blown out the old stuff or can you do it with the shield on?
thankyou!!
pracy is offline   Reply With Quote
Old 06-17-2008, 06:11 AM   #2
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
i buy cheap 1 dollar bearings from amain or avid use them for a race day or 2 then throw them away
cheesecake is offline   Reply With Quote
Old 06-17-2008, 07:49 AM   #3
newbie2's Avatar
Trader Rating: 17 (100%+)
Default clutch
I agree with cheesecake, but being a titewad its hard to throw away good bearings.. I boil them in mobil 1 an reuse. I do this after a weekend of racing. yet to have a bearing failure. sure its a lot of extra work but I enjoy doing it and I"m saving a few bucks... good luck
newbie2 is offline   Reply With Quote
Old 06-17-2008, 07:52 AM   #4
Trader Rating: 27 (100%+)
One drop of marvel mystery oil in each bearing after race day keeps my bearings lasting a long time. When they start feeling gritty or wobbly replace them. To much oil and you just end up soaking the clutch shoes/bell with oil that is thrown off.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 06-17-2008, 08:18 AM   #5
blktransam's Avatar
Trader Rating: 59 (100%+)
cheezeball is correct on this one...just use boca or avid -1.00 each and swap them out after every race... 2.00 is all it costs and if that is too much u are in the wrong hobby lol
blktransam is offline   Reply With Quote
Old 06-17-2008, 09:20 AM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
And since you really need to pull the motor to do that... why not just replace the bearings? Cheap insurance. There's nothing worse than the feeling of not finishing a race because of something like a bearing failure that you could have prevented.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-17-2008, 10:15 AM   #7
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i just put in new ones.. i never worry about oil or grease. if they are gritty toss them IMO
jamminnay is offline   Reply With Quote
Old 06-17-2008, 10:42 AM   #8
Toiffel's Avatar
Trader Rating: 52 (100%+)
TKO bearings my friend, u will never regret using them, I made the switch just a few weeks ago, and still haven't blown one yet, run them in truggy and buggy!!!!!
Toiffel is offline   Reply With Quote
Old 06-17-2008, 10:50 AM   #9
How much are they? Are they steel or ceramic?
blowpopracer is offline   Reply With Quote
Old 06-17-2008, 10:51 AM   #10
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
I agree with Toiffel! TKO is the ticket! To clean and relube I pop one sheild out and use the sonic turbo wash tub sold at TKO and relube with a little Euraka lube also sold at TKO.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-17-2008, 10:54 AM   #11
jpalessi's Avatar
Steel.. They are marked as the "special" clutch bearings. Well worth a little extra $$$
Joe Alessi
www.Lucky7RC.com
Old 06-17-2008, 11:25 AM   #12
slow coach's Avatar
buy in packs of ten from walawala store on flea bay, remove all the grease then re-oil with acer sin lube, no clutch slip from lube been thrown over the clutch which always happened with greased bearings and the bearings are now supersonic
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 06-17-2008, 11:28 AM   #13
Tony Newland's Avatar
Trader Rating: 50 (100%+)
I've used Avid revolutions since they came out and not had a single clutch bearing failure in that time......
I pull the yellow seal off and blow the grease out with either an air compressor or motor spray (I've ran them dry for years-no lube).... re-install seal and run them for about a gallon and throw them away. It doesnt matter which way you run the seal, I've ran them both and there's no difference in life.
The key to clutch bearing life if chassis flex and having enough fore and aft play. I run alot of play, 2-3mm and my car's chassis doesnt allow the clutch bell to hit the chassis. Not monitoring these 2 things will cost you a grundle in bearings....
Avid revolutions - dead reliable and cheap $1/ea
Ceramics for me have been nothing but problems
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 06-17-2008, 11:40 AM   #14
slow coach's Avatar
Good point Tony when meshing i cut a strip of paper from a normal A4 printer sheet just wider than the cb gears fold it in half then work it between spur and cb, push motor so cb is tight to spur tighten motor down remove paper you need to turn spur to get it out and you now have a well meshed cb/spur it works every time
Old 06-17-2008, 11:45 AM   #15
I also do that for mesh settings
Bearing maintenance scarymonster Electric On-Road 7 10-01-2007 07:03 AM
Bearing maintenance scarymonster Northwest Racers 4 09-30-2007 08:32 PM
Bearing maintenance AMGRacer Nitro On-Road 15 07-30-2007 03:54 PM
Bearing Maintenance Mossie Australian Racing 38 07-13-2004 03:54 PM
Bearing Maintenance S15Racer Electric On-Road 3 05-01-2004 08:54 PM
