Whats the easiest way to put Clutch shoes on a 8T
Just like the title says. Im trying to put the shoes on my 8T, and after jabbing a screwdriver through my finger im not enjoying this design at all. Whats the easiest way to do this?
R/C Tech Elite Member
Trader Rating: 123 (100%+)
You have to just line up one hole at a time. You will have to apply a bit of pressure to the shoe toward the clutch center to get the pin through the bottom hole. I have put a very slight taper on the end of the pins to assist with finding the hole After you get a few, it goes real easy. I just keep turning the pin back and forth with my hex as I line up each hole and apply pressure to offset the spring tension and all is good.
Thanks, I will try to round off the end of the screw
I spent 2 hours before I got on here and asked.
I finally got it in about 5 minutes after rounding the screws off.
After battling my 8 and 8T clutches for the last few months I decided to find a way to fix this once and for all so I didn't have to go through dremeling the pins one at a time every time I changed the clutches.
I was at the track and my Composites gave out - the aluminum were still good. Decided to swap them all out and get back out - as I am stubborn and do not want to leave practice nights.
I needed a ten minute solution to a clutch swap at the track and they say necessity is the mother of invention....... So in a moment of desperation I pulled out all new clutches, springs, pins and stuck them all in the flywheel and got them started.
Reach around behind me and grab a tie strap and zipped it around the clutch tight. It pulled all the clutch shoes in perfect and I just gave the shoe a nudge sideways to drop the pin in the hole.
BAM....... I was able to swap my clutches in 5 minutes and I have done it twice since then. No shaving, drilling, cursing..... Zip tie the clutch and slide the shoe a little to the right (the natural direction the spring pushes the shoe is left) and the pins drop in like butter........
Hope it helps you all in the future.
Thanks, that should be the best way without causing any damage to the shoes or flywheel. Great idea.
