Old 06-16-2008, 09:44 AM   #31
JQ
Actually, when people refer to running crime fighters up front, and bow ties back, people like Truhe and Drake, they call them bowfighters.......
Originally Posted by Seyruuen View Post
"Bowfighers" would be bowties up front and crimefighters in the back.. the name for the tire combo we are spekaing about is "CrimeTies".
The naming convention uses the front tire name first, and the back tire name last. Panther tires which have single names are used as an equivalent. I Have heard "KomodoGators" but only from Panther guys.
say it wrong and people look at you funny, especially at nationals.
JQ is offline   Reply With Quote
Old 06-16-2008, 10:16 AM   #32
sp2thielen's Avatar
Send a message via MSN to sp2thielen
what is the best track condition for running the tires in either configuration? i tried them on dry loose and was loose in the rear. what kind of track surfae is this compatabile with?
IMPULSE RC when only the very best will do!!!!
Hobbytown Hobbyplex
Kyosho SP2/ Medial Pro
Kyosho ST-RR/ Medial Pro
sp2thielen is offline   Reply With Quote
Old 06-16-2008, 10:31 AM   #33
Tech Legend
Wild Cherry's Avatar
Bowfighter`s perform well on hard pack blue groove and real dusty layouts ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-16-2008, 10:34 AM   #34
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i run bowfighters all of the time.. love the setup!!
jamminnay is offline   Reply With Quote
Old 06-16-2008, 10:48 AM   #35
Originally Posted by gearheadz80 View Post
Pro-lines foams are the problem.
Before you mount them up. Check the balance of the bare rim, next check the balance with the rim and foam with no tire, and then check it with the rim/tire and no foam. If you mess around with it you will see how bad the foams really are.
One way to lessen the amount of weights needed is to counter balance the heavy spot of the foam with the light spot on the rim/tire before you glue them. PITA but it helps abit
Im sure some of you have heard me say this before, but proline is garbage and most people know it.
I was aware it was shitty company, but this thread just confirmed it even more.
stay away from proline and himoto and you will be fine.
new to rc cars is offline   Reply With Quote
Old 06-16-2008, 11:12 AM   #36
Tech Legend
Most @ this year`s Roar Nats would disagree with your bashing ....
Including the winner....
George W. Cherry
Old 06-16-2008, 12:32 PM   #37
Eccentric's Avatar
Double post. Delete please!!!
-Aaron
Dangit, when did all my favorite cars, trucks, airplanes, and engines become "vintage"???
Eccentric is offline   Reply With Quote
Old 06-16-2008, 12:32 PM   #38
Eccentric's Avatar
Regardless of what your opinion of Pro-Line is, how does this thread "confirm it"???
-Aaron
Old 06-16-2008, 03:39 PM   #39
jamminnay's Avatar
i run pro-line all of the time.. i would have to say they are pretty dang good at making tires. i am not sure how this thread confirms that there tires are junk??
Old 06-16-2008, 04:33 PM   #40
wes95_z28's Avatar
Originally Posted by DOMIT View Post
That was a little uncalled for...
Yes it was, I went over the line. I was having a bad day yesterday and I was going off on everybody, just ask my wife.
Integra I do apologize for being such an ass. I was merely stating, that spending the time to perfectly balance your tires the way you claimed in an earlier post in this thread is a waist of time to me. I DO balance my tires, but when I balance them, its just a quick couple of spins, get it close and run them type deal.
Pro-line tires usually do require a bit more balancing to be perfect, I personally feel that it is there foams, not the tire. I feel that panther tires are more outta balance than some of the prolines. But do keep in mind, every set you get will vary greatly.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 06-16-2008, 04:37 PM   #41
Integra's Avatar
have u ever balanced a set of them....then u would know.
Old 06-16-2008, 06:09 PM   #42
I always knew something about them wasnt quite right, now that I hear from about 4 other guys that they are off balance... well that confirms it.
same as above, I have had problems with a few of prolines items, tire scrapers, tire glue, rims stripping in 10 mins, fuel bottle cracked, like a 6 inch long crack in the bottle because I dropped it, few more I cant quite remember. I know im not a big fan of proline anymnore...
Old 06-16-2008, 07:14 PM   #43
Tech Legend
I thought this thread was about Bowfighter`s ?
George W. Cherry
Old 06-16-2008, 08:58 PM   #44
Trader Rating: 19 (100%+)
Yeah me too LOL. I like Panthers 10th scale tires alot. But truggy ar buggy tires I wouldnt even know what to get "Komodo dragons"? I read about people runnin Gators but thats in California I am in Pa, BIG DIFFERENCE. The Kimodo's look like the closest thing to what I may need. What about the LPR style you know big wheel little sidewall what is that for? I was thinking about trying bowfighters and lpr at the same time but I dont know if the lpr is for my local tracks.
malik is offline   Reply With Quote
Old 06-17-2008, 09:39 AM   #45
MikeFriery's Avatar
Bowfighters work the best of any tire on about 90% of the tracks i've ever been too. They work good on wet and dry hard packed tracks and also on wet loamy tracks
MikeFriery is offline   Reply With Quote
