Old 06-11-2008, 05:49 AM   #1
rcdaddy's Avatar
Default Problem on new 8T
I have a Losi 8T pro roller that is brand new. I havent even put servos on it yet. I was going to get all the stuff put on it and I noticed when the center diff is turning while on the truggy it feels like something is binding. I have looked while spinning the center diff and can not see anything such as the brake linkage rubbing. There is no wear or marks on the diff case. It is just not smooth in spots while turning. Again this thing is brand new. Has anyone seen this and if so what do I need to check? Could it be the internal diff gears even though its new? Any help would be greatly appreciated. Thanks in advance for the help.
Drive It Hard and it Will Be Fast
Nova Rossi, Jammin, Team Associated, OS Engines, Futaba, Airtronics, Go Engines, RB Mods, Fusion Motorsports
WCRC Raceway
Big Billy's RC World
Baity's RC
rcdaddy is offline   Reply With Quote
Old 06-11-2008, 06:04 AM   #2
busta774's Avatar
Send a message via MSN to busta774
if you read through the losi manual near the back it tells you that you got to break in the differential's: while holding the chassis with ONLY the left side tires firmly on the ground.give the car about one eigth throttle, for 30 seconds. the right side tires should spin freely during this time. repeat this with ONLY the right side tires hel firmly to the ground, allowing the left tires to spin. repeat these steps at least two more times. hope that helps cheers
busta774 is offline   Reply With Quote
Old 06-11-2008, 07:05 AM   #3
rcdaddy's Avatar
Thanks, thats what I was hoping. I do not have the manual, I am printing it right now. I appreciate your help.
WCRC Raceway
Baity's RC
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 07:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 08:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 06:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 04:08 AM
