Old 06-09-2008, 10:00 PM   #1
mike williams's Avatar
Trader Rating: 45 (100%+)
Questions?? losi 8 diff question**HELP**
i just took apart the rear diff in my buggy so i could change diff oil, clean, and install new bearings. And when i reassembled everything in noticed that the ring to pinion mesh is pretty tight. when i pulled everything apart there were no shims or anything for alignment. im not sure what to do, shims or what. any help would be great as usual as i gonna do the same to the front and would like to remedy this problem so i don't have to pull it a part multiple times.Thanks a million!!!
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 06-09-2008, 10:56 PM   #2
RETRO RC's Avatar
hey mike theres a few things you can check,
#1 make sure that you haven't over tightened the gear box
#2 check that the rear bearing inserts are seated properly some times they rotate a little and can cause some problems.
#3 make sure that the pinion and coupler are tight and that there is no play
#4 did you also use a new gasket when you did the rebuild if not you should try replacing that, if you did check that the ring gear isn't over tightened causing the gasket to flatten out too much
hope that helps
Adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 07:49 PM
Losi XXX-NT Diff question sullen909 Nitro Off-Road 9 08-24-2008 03:51 PM
TC4 Diff question Raydee Electric On-Road 6 04-30-2007 03:56 PM
diff question andy_666 Electric Off-Road 3 03-18-2005 08:57 AM
1/12 Diff Question Takt Electric On-Road 23 12-09-2004 01:26 PM
