Old 06-08-2008, 08:58 PM   #1
HEAT's Avatar
Trader Rating: 26 (100%+)
Default lil help needed
I havent had good luck with clutch bell bearings , so can i get some help on how to shim my bell the correct way !
mugen flywheel
Dynamite Max-Life Aluminum Clutch Shoes
losi clutch bell
" setup if this helps "
Thanks for any help ...
HEAT is offline   Reply With Quote
Old 06-08-2008, 09:01 PM   #2
jgtruggy's Avatar
mugen flywheel
losi clutch bell
do you have the extended engine mount? If not, the chassi flexes a ton which will cause your front clutch bearing to go quickly. I use the kingheadz extended engine mount. Works good
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Old 06-08-2008, 09:07 PM   #3
Integra's Avatar
set the CB/Spur mesh SLOPPY....like almost to the point u 2nd guess urself....that solved my bearing issues...but then again i do have the KH ext motor mount...and both chassy braces....try the mesh...then go to the motor mount.
NEEDED-RC CRAWLER FORUM-NEEDED countryboy4life R/C Tech Site Forum 9 03-11-2010 07:07 PM
Help Needed! Supa_Mario Nitro On-Road 1 02-19-2008 09:00 AM
pro 4 help needed minnesh Electric On-Road 2 02-27-2007 08:30 PM
Help needed.. xpander77 Singapore R/C Racers 3 12-04-2004 06:57 AM
Help Needed HPIRS4GUY Australian Racing 6 02-22-2003 11:40 PM
