Old 06-08-2008, 06:13 PM   #1
Trader Rating: 38 (100%+)
Default where do I put the after run oil?
Do I pull the glow plug and put a drop or two in there?
vw addict is offline   Reply With Quote
Old 06-08-2008, 06:19 PM   #2
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
You can either put it in the hole where the glow plug goes or put it in in the carb after you take the air filter off. If you are using the hobbico after run oil I think they say to put 2 or 3 drops in.
crazy4wdracer is offline   Reply With Quote
Old 06-08-2008, 06:21 PM   #3
The Joker's Avatar
It's best to put it in the glow plug hole & the carb! 5-drops in each.
The Joker is offline   Reply With Quote
Old 06-08-2008, 06:25 PM   #4
Thanks man. I pulled the glow plug, put two drops in, pulled the starter twice, and put the glow plug back in.
