Old 06-06-2008, 01:20 AM   #1
Default Chaps any advice wanted Please Novarossi ?
Hey all,
Just wanted to clear up a few points if possible,
Im currently looking at buying a new motor quite possibly a novarossi 21-5k or the 21-7
Now im not sure which one to go for but im leaning towards the 21-5k, and im going for the novarossi efra 3005 pipe
Now ive heard rumours your only meant to run these on a max of 25% nitro? is this correct as i run 30% currently but if i can only use 25% thats no biggy
how likely would it be to get the elusive 10min run times at the moment i use a os speed in the x1cr and get around 9max with a jp4 and odonnels 30%
I know its dependant on all sorts of criteria but has anyone managed it
Cheers all
Megacrash is offline   Reply With Quote
Old 06-06-2008, 11:27 AM   #2
Those are all hard questions cause it varies alot on your track. I can tell you that if you wanna run 30% fuel all you have to do is add a extra head shim which probably will come with your new engine.
As far as which engine... generally less ports=more low end, more ports=more top end. So if you have a big open track I would do the 21-7, if you have a smaller track where you are in and out of the throttle alot i would do the 21-5.
Hope that helps.
blowpopracer is offline   Reply With Quote
Old 06-06-2008, 05:35 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
The 21-5k should be able to attain 10 minute runtimes. It will depend on how much throttle you use and tuning. In general, add 0.10mm shim for 30% fuel. You can generally rip it out after break-in or 2 gallons. I would suggest replacing the rear bearing also at 1.5 to 2 gallons.
You current setup in your car has been ran with 15min+ runtimes, so if your getting 9min, your tuning, driving style or track maybe determining your current runtimes.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 06-06-2008, 06:18 PM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
They should run fine on 30% without adding a shim. I have run as much as 33% on Nova's with stock head clearance. Yes they are set-up for 25 but they are also set-up on the safe side so 30 is no problem.
wingracer is offline   Reply With Quote
Old 06-06-2008, 07:15 PM   #5
My 21-5kt can get about 12 minutes in practice (truggy), and depending on how I am racing, I can get 9:30-10:30 on a tank. If you are going to get this mill, I would advise you to get the turbo head. The turbo head really smooths out the engine, gives it a bit more oomph, and tunes easier imo. I run OD97T plugs in mine, 1 additional thin shim, 30% fuel, and 53 pipe...oh yeah, don't expect it to run with that Speed of yours...it does not have a top end like the Speed does, but the powerband is smooth and it pulls good all the way to the top, but the Speed is definately faster imo
gtsum is offline   Reply With Quote
Old 06-07-2008, 12:00 PM   #6
Thanks Chaps,
Greatly aprecieated
1/18th Outdoor Off road track design advice wanted imjonah Micro and Mini Scales 6 07-01-2008 09:14 AM
ESC advice please chaps TRFTIM Electric On-Road 4 09-05-2006 01:15 AM
Wanted-Novarossi carb macnkitty2002 R/C Items: Wanted to Buy 6 07-14-2004 08:38 PM
Advice on Fuel etc on Novarossi NSR 5Port ttektek Nitro On-Road 2 11-23-2003 10:39 PM
New to RC, Advice wanted. Moose Australian Racing 33 04-28-2003 10:02 PM
