Old 06-05-2008, 07:11 PM   #1
KJT4's Avatar
Default How hot?
How hot does your engine get?
Kieran Codd-
T4.1-LRP Sphere Comp, X-12 -Spetrum DX3C-ProTec 5600-Hitec HS-7954SH
KJT4 is offline   Reply With Quote
Old 06-05-2008, 07:21 PM   #2
To tell you the truth I dont worry too much about temp as long as it is running properly and blowing smoke. I dont like to run my engines any cooler than 200 degrees because I feel it can cause wear more rapidly to the piston/sleeve. Normally I am real happy if it is 240-260 but that is just in general. I have one engine that runs best at 290 which some people would kringe at but it runs fine and blows plenty of smoke so I leave it.
blowpopracer is offline   Reply With Quote
Old 06-05-2008, 07:29 PM   #3
Vigilante212's Avatar
Yea anywhere from 220 - 300 is fine, but most engines seem to run best at the 220-260 range. And thins is just a general guideline like blowpop said if it runs good and blows smoke at 290 run it there. engines run differently with different fuels also.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 06-05-2008, 07:38 PM   #4
pl_unc86's Avatar
Trader Rating: 16 (100%+)
I just wanted to confirm that the Avid Indo brakes for the xb8 or xb8r will fit on the 808. I know i read somewhere they would, but i just wanted to confirm. Thanks
Here is the link
http://www.avidrc.com/shop/?action=i...=4&prevstart=0
pl_unc86 is offline   Reply With Quote
Old 06-05-2008, 07:45 PM   #5
pl_unc86's Avatar
oops wrong thread
Old 06-09-2008, 01:20 AM   #6
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Hi, I also feel like what you mention on if running rich it might wear the piston and sleeve more fast then run a little hot. Later this weekend I will make my engine to run ~230-240 with smoke out from pipe
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 06-09-2008, 01:43 AM   #7
Sound and smoke people, sound and smoke! Remember your temp. gun can be off 20-30* one way or the other.
The Working Man is offline   Reply With Quote
Old 06-09-2008, 02:43 AM   #8
Registered User
So your saying go Smoking Hot!!!
Loop&Roll is offline   Reply With Quote
