Old 06-05-2008, 12:45 PM   #1
wheelhead's Avatar
Send a message via AIM to wheelhead Send a message via Yahoo to wheelhead
Default Witch plug should i use
I have an sts.12rs and looking for some help on witch plug i should use. I think a had a os5r in it but not sure. The plug is all black. Just got a race coming up and want to get some new plugs for it. Any help would be great.
CRT.5
STS .12RS 3port
Ofna High Down Force Wing/Yellow
12mm Rear Shocks/Drilled
http://grandwoodsrc.com/
wheelhead is offline   Reply With Quote
Old 06-05-2008, 01:22 PM   #2
Trader Rating: 17 (100%+)
As a rule of thumb, the higher the nitro content the cooler the plug. If your running 30% nitro you'll want to run a med. to med. cold plug. Run a plug that is too far down on the cold scale and you'll have trouble with idling and getting it tuned properly. Running a plug that is too hot and you'll have detonation problems. If the detonation is severe enough, it will burn a hole in the piston. You can also fudge a little in either direction depending on the weather conditions. I prefer to run a med. plug because the engine idles and tunes good plus it doesn't cause detonation problems
rcdude69 is offline   Reply With Quote
Old 06-05-2008, 01:39 PM   #3
wheelhead's Avatar
As of right now its running on traxxas topfuel 33 but it will be going to sidewinder race blen 20 after that. Iwas was wondering if i should go if a short plug like the os's or a mcoy8/9 plug. Ido live in Michigan were the temp can get into the 90's too
CRT.5
STS .12RS 3port
WITCH PIPE??????????????? ktmusa Oval, Larger Scales and More 11 08-27-2010 06:48 AM
I want a V SPEC, but witch one? badassrevo Nitro Off-Road 17 07-06-2008 07:40 AM
witch one do you like ?? marvin397 Painting, Designs, Graphics and Photography 1 03-29-2008 11:14 PM
witch 4wd buggy? sbmammoth Rookie Zone 4 04-06-2007 12:33 PM
witch Esc is best for about 70-100$ Rasmus TbEvo IV Electric On-Road 16 12-04-2005 11:19 AM
