Sleeve removal
Old 06-04-2008, 07:34 PM
Default Sleeve removal
Im taking apart my plus 21-5k and cant get the sleeve out. Can I bake it to expand hte metal? If so how hot? Thanks.
skmo815 is offline
Old 06-04-2008, 07:38 PM
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
did you use the zip tie method?
Flying Monkey is offline
Old 06-05-2008, 03:52 AM
Trader Rating: 19 (100%+)
I leave the flywheel on for a handhold and use the ziptie, fold it over and put it in the exhaust port, then rotate flywheel and it pushes out the sleeve. Never tried heating it, I think it would melt the ziptie.
pooldoc is offline
Old 06-05-2008, 07:14 AM
Put a heat gun right on top of the sleeve for about 10-15 seconds. Then put the zip tie in and it comes out smooth as butter.
stiffler297 is offline
Old 06-05-2008, 08:01 AM
If the zip tie fails to do the trick, use the end of a tooth brush. Remove the back plate and bush the sleeve up with the end of the tooth brush, also heat it before trying to pop it out.
nascardad24 is offline
Old 06-05-2008, 08:50 AM
jamminnay's Avatar
i always use the zip tie method.. i havent had one yet that wont come out
jamminnay is offline
