Old 06-02-2008, 04:31 AM   #1
mike williams's Avatar
Trader Rating: 45 (100%+)
Questions?? tire gluing help needed...please!!!
i bought a set of tires and when i assembled them I thought that they were glued together good but when i ran them the first time they came apart. The glue did not take very well to the rims. so, i need help to get the old glue off and how to properly prep them so this does not happen again...as alway, any help is greatly appreciated....thanks in advance
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 06-02-2008, 04:51 AM   #2
this will help you, if not ask any more questions...
http://www.prolineracing.com/t-howto...emounting.aspx
pracy is offline   Reply With Quote
Old 06-02-2008, 06:03 AM   #3
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
There are two methods for removing the tire from the rim that I know of. The first is boiling the tire/rim, the second is by putting the tire/rim in the oven for a brief period of time. Ive tried both methods with limited success. The idea is to heat the glue to the point where it breaks down then you can remove the tire. to get the rest of the glue off the rim, you may try a dremel. Ive done this on touring car tires and it worked pretty well. I am about to try on an 8th tire, my nut came loose and the hex got all wallowed out so I need to try this on one tire.....
-M
MikeDeadly is offline   Reply With Quote
Old 06-02-2008, 07:11 AM   #4
UN4RACING's Avatar
Trader Rating: 22 (100%+)
What brand? Gluing sucks. I just glued a couple of sets and once ou get the hang of it its not to bad. Take your time and kinda set up and do a dry test run to get your method down. I hate a wobbly tire.
after about 3 sets I am getting the hang of it tot he point they are looking pre glued.
UN4RACING is offline   Reply With Quote
Old 06-02-2008, 07:15 AM   #5
UN4RACING's Avatar
Heres a good link posted for me I was trying to get the hang of it.
I prefer a slow drying glue the slower the better.
http://www.nitrohouse.com/video_help.htm
Good info on this site.
Old 06-02-2008, 07:56 AM   #6
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
not to high jack the thread here but i have a similar question. how do you glue tires to aluminum rims? do you glue them the same way, or is there something special you have to do? I am only used to glues with the plastic rims. Some help would be great.
dieseldog20 is offline   Reply With Quote
Old 06-02-2008, 08:06 AM   #7
MikeDeadly's Avatar
On gluing to alum rims, I would make sure the alum surface is a little roughed up first, but you should be able to use the same CA that is used for plastic rims. I would check it often for separation though, Ive never personally used alum rims.
Old 06-02-2008, 08:21 AM   #8
desertbird's Avatar
Soak the rims in acetone overnight and any pieces of tire and glue will come off very easily the next day. Must be submersed to work. This works to refit any rim even if glued properly the first time. Stole idea from someone on here about reusing rims. It works great.
desertbird is offline   Reply With Quote
Old 06-02-2008, 06:28 PM   #9
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
there is no shame in pre mounts!!! i can go glue tires i just dont wanna waste the time..
jamminnay is offline   Reply With Quote
Old 06-02-2008, 07:31 PM   #10
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
I've had great success with the oven method.. Preheat oven to 500 , once oven is up to temp, turn off the oven, and put tires in on baking sheet, leave in "off oven" for 7 to 10 mins. Pull out 1 at a time wearing heavy leather gloves, and peel tire off rim with ease. If tire doesn't peel off very easy, put it back in oven and try again in a couple of mins.
As for gluing clean rim and tire with Nexgen mold release cleaner and use Lucky 7 Rc tire glue. Both available at www.TKOcompetitiondev.com Good luck!
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-02-2008, 07:36 PM   #11
thanks for the info..the NITROHOUSE video is great.....i'm gonna try the boiling method to remove the remaining glue thats holding. just wondering what it's gonna do to the foam?...well..we will see.Thanks again!!
Old 06-02-2008, 08:21 PM   #12
UN4RACING's Avatar
Amen thats my plan. Tire gluing is a third job.
Old 06-03-2008, 08:16 AM   #13
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Just a couple things to help:
Get a sanding drum for your dremel... or do it by hand with sandpaper. Make sure you scuff the bead area on the rim... and be sure you sand enough to get ALL of the shiny part and the mold release off the bead area of the tire. Clean them both with denatured alcohol after.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-03-2008, 08:53 AM   #14
Integra's Avatar
i wont trust premounts....ive seen too many come off the rim with em....I prefer to do ALL my own glueing...its a cake walk once uve done a couple dozen
Old 06-03-2008, 03:11 PM   #15
UN4RACING's Avatar
I need to edit my early post. This post is right. I have gotten the hang of it know and how right it gets easier.
The reason i have changed my ming on pre mounts is that one of the sets I glued I put a set of integy yellow inserts in it and tossed the stock foam. I poked 4 small holes in the tires 1st and now that they are glued they feel great. better than the stock ones I have that are pre mounted.
So there are advantages to gluing your own. I think I will glue my own.
The art of tire gluing. CE28N Electric Off-Road 15 09-12-2008 05:53 AM
Tire Gluing acutts Electric On-Road 15 06-01-2005 04:04 PM
tire gluing scotwithonly1t Electric On-Road 9 11-07-2004 12:35 PM
Take-Off Tire Gluing Method FREAKAH Electric On-Road 1 10-24-2004 03:06 AM
Foam Tire gluing question sands Electric On-Road 1 11-06-2003 04:52 PM
