Old 05-31-2008, 07:38 AM   #16
water ballons are an awesome alternative heres a quick pic
you can also choose what color you want
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 05-31-2008, 07:43 AM   #17
Integra's Avatar
with ballons your shocks dont get FULL compression...how do u feel about that....Inconsistent shocks are Definatly not on my list of things to have.
Old 05-31-2008, 07:58 AM   #18
I tried the shrink wrap thing and found terrible shock action,ballons will retain air pressure during shock travel so I poke holes each end with a push pin and they seem to work reasonably well and you can't beat the price.
dogger is offline   Reply With Quote
Old 05-31-2008, 08:27 AM   #19
Integra's Avatar
X2 on the shrink idea...that would 100% Dumb down the action of the spring....if u shrinked it TOO much you would be Choking the spring...Not a good idea imo.
Old 05-31-2008, 02:44 PM   #20
markfanelli's Avatar
If you use the right ballons they will not affect the droop. And if your gonna poke some holes in it your just defeating the purpose of having them in the first place, to keep dirt out. I have been using the balloons that TKO sells and recently found the same ones on ebay. They are not your regular party ballons you get at the dollar store they are 260 qualatex and are very durable.
markfanelli is offline   Reply With Quote
Old 05-31-2008, 03:08 PM   #21
Integra's Avatar
if u dont poke breather holes in them they Puff up like ballons on full droop and also suck on the shaft when u try to go full extention...why do most boots have holes in them then.
Old 05-31-2008, 05:14 PM   #22
Powerlink's Avatar
Send a message via AIM to Powerlink
A small slice in the boot is a good thing a hole will let dirt in depending on the size of the hole . I started to put a small slice in mine because it will stay closed until shock compression has started, then it will open . It has worked very nicely for me...
Karl Rolf
Powerlink is offline   Reply With Quote
Old 05-31-2008, 06:08 PM   #23
Integra's Avatar
thats a good idea....but i would think just like tires....a slit will rip easier then a purfect hole will....but maby not.
Old 05-31-2008, 06:19 PM   #24
lowey79's Avatar
i use the animal baloons as well with great success.... No holes or slits just cut them to length and put them on. Yes they do limit compression travel, but we're talking 1-2mm max and from what i've seen they act more like bump stops so ur shocks dont bottom out hard.... Not that mine do, the chassis hits the ground before that happens. Poeple will have there opinions for and against the same as every other product/idea in rc, that's what makes it so much fun!
Balloons are all good IMO, if you like them, use them........
lowey79 is offline   Reply With Quote
Old 06-23-2010, 07:31 PM   #25
wfo
wfo's Avatar
260Q size work the best 100pcs for 6.50 ill try it and toss them after every race like i do bearings...
wfo is offline   Reply With Quote
Old 06-23-2010, 08:14 PM   #26
Peter Martin's Avatar
http://tkocompetitiondev.com/index.php?cPath=38_95
Peter Martin is offline   Reply With Quote
Old 06-23-2010, 09:03 PM   #27
houston's Avatar
Trader Rating: 91 (100%+)
use the black ones from party supply store they hold up very well
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-23-2010, 09:26 PM   #28
Trader Rating: 30 (100%+)
well on full compression if you poke hole in them with hobby knife to relieve air they get full compression igleast on xray they do your shock doesnt compress fully before the chassis slaps so the 1/16th inch comp. you loose wont hurt
also tko makes bag of 100 black ballons for like 12 bucks
jewn_beef is offline   Reply With Quote
Old 06-24-2010, 04:41 AM   #29
jammin32j's Avatar
I use Rocket balloons, they taper down at the bottom and fit over the ball end just like a regular shock boot does. I cut them to length and use a O-ring to hold them on to the shock body. A pack of 5 is a buck at Wal-Mart.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 06-24-2010, 07:49 AM   #30
rc skyline's Avatar
Originally Posted by Dan Reino View Post
I get a bag of Water Ballons from Target. 100 ballons for $1.00 they work great on Jammin, Losi, Asso. Xray 808......
And Mugens
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Shock Boots ecko51 Electric Off-Road 12 02-22-2011 12:01 AM
mugen shock boots on a nitrage...? mad-dog Nitro Off-Road 0 08-18-2007 09:52 PM
Shock Boots Smaxxblue Monster Trucks 4 02-25-2005 06:13 AM
NoTies Shock Boots JubJub R/C Items: For Sale/Trade 0 07-23-2003 06:00 PM
