Old 05-29-2008, 12:29 AM   #1
NEMESIS44's Avatar
Send a message via AIM to NEMESIS44
Default Can't get my sleeve out
I was in the process of removing my sleeve by putting zip-ties in the ports and rolling the piston up when it got stuck. It is sticking out of the block about a 1/4in.,won't go any further. Keeps snapping the zip-ties off. I even tried going to a big zip and putting two through the exhaust port. Exhaust is the only port I can get one in. The engine is a Hotmod Nova. Plus 21-7 if it matters. Anyone got a solution for me?
Losi 8ight 2.0,Werks B6, Spektrum, Savox HVs, AKA
Loving me some FRC!
NEMESIS44 is offline   Reply With Quote
Old 05-29-2008, 12:30 AM   #2
Steve Walters's Avatar
Heat it up with a heat gun to 250....
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 05-29-2008, 12:42 AM   #3
NEMESIS44's Avatar
Thanks Steve you always seem to know a trick although you make me feel stupid most of the time.
Loving me some FRC!
Old 05-29-2008, 06:16 AM   #4
Revo-lution's Avatar
Trader Rating: 14 (100%+)
You better be quick with that zip tie at that temp.
~ Go big or go home ~
~ Novarossi powered 8T 1.0 - A.K.A. 4.0~
Revo-lution is offline   Reply With Quote
Old 05-29-2008, 07:28 AM   #5
use the head of the ziptie
thekid22 is offline   Reply With Quote
Old 05-29-2008, 01:17 PM   #6
There's no stupid questions...
Glad if it helps...
BCE 8X8 Pro Chassis
Hitec 5995TG (S&T)
M11 & Spectrum.
Old 05-30-2008, 01:28 AM   #7
You can also try putting a little after run oil around the sleeve thru the area where the backplate is or wd40 and let it sit for a while. Then heat it up and use the ziptie method. If that doesnt work I used a peice of servo horn or any thicker plastic instead of a zip tie.
Genius is offline   Reply With Quote
Old 05-30-2008, 07:09 AM   #8
did you snap a rod?
if so the rod might of hit the bottom of the sleeve in action of snapping and kinked witch wont let you slip it out
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
WTB - SLEEVE CRIMPER Green Machine Australia Wanted to Buy 2 03-28-2008 03:56 PM
new sleeve papadocks Electric Off-Road 2 05-10-2007 06:12 PM
how to take out the sleeve dotmatrix Nitro On-Road 17 12-05-2006 03:41 PM
FS: NIB AE .15 Piston & Sleeve Set SteveM R/C Items: For Sale/Trade 0 05-23-2006 02:30 PM
where to buy new NS3 sleeve? one-nil Hong Kong Racing 0 07-07-2005 02:56 AM
