Old 05-28-2008, 11:00 PM   #1
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Default Guide: Removing flywheel
This is a guide on how to take your flywheel off, this is somewhat complicated for new people, when they have to swap there engines and have to keep there fly wheel for the second engine.
Tools you will need.
Guide: Removing flywheel-tylers-tutorials-007.jpg
Some sort of a clamp, an 8mm socket wrench, rubber hammer or something that wont hurt the fly wheel. and of course. THE ENGINE!!
Set the clamp to VERY tightly hold onto the fly wheel.
Guide: Removing flywheel-tylers-tutorials-002.jpg
Then grab your 8mm socket
Guide: Removing flywheel-tylers-tutorials-003.jpg
then attach to the nut
Turn and hold untill the nut is off
Guide: Removing flywheel-tylers-tutorials-005.jpg
Then hit the back off the fly wheel, i used my hex wrench set, in different spots untill it comes off. Then you have this!
Guide: Removing flywheel-tylers-tutorials-006.jpg
Your done!
make it a sticky??
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 05-28-2008, 11:11 PM   #2
Trader Rating: 5 (86%+)
After removing the flywheel nut, i usually take a fat flathead screw driver and pry between the flywheel and the crankcase in different spots.
Thanks for sharing your thoughts though! It was very kind of you!
razor_clawzz is offline   Reply With Quote
Old 05-28-2008, 11:30 PM   #3
wes95_z28's Avatar
Razor: That is really only a good idea if the motor you are taking the flywheel off of is junk. If you are doing maintenance you run the risk of damaging the front engine bearing with the screwdriver.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 05-29-2008, 06:00 AM   #4
Integra's Avatar
..Im shocked.
Old 05-29-2008, 06:57 AM   #5
HulkNT1's Avatar
Is it easier to get a fly wheel puller than risking a damage engine. A good flywheel puller are like $25 to $35 and not risking hundreds of dollar in damage..
HulkNT1 is offline   Reply With Quote
Old 05-29-2008, 07:58 AM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
+1
Also a flywheel puller is virtually no effort to use... very fast, no frustration...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-29-2008, 08:28 AM   #7
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Default b
Are those three poles* that the shoes and springs removable or will they come with a new flywheel? My flywheel is smooth and wont catch the boxs' wheel anymore.
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 05-29-2008, 08:50 AM   #8
Powerlink's Avatar
Send a message via AIM to Powerlink
I know some people are buying batt. clamp pullers, there cheap and work good. I use this http://www.amainhobbies.com/product_...oducts_id/5547
and this http://www.amainhobbies.com/product_...oducts_id/4098
I also heat up the crank case a little ,comes off like butter . I know they are a little more $ however no risk no damage to anything and they last ..
Karl Rolf
Powerlink is offline   Reply With Quote
Old 05-29-2008, 10:38 AM   #9
Suspended
I've seen multiple crankshafts broken with flywheel pullers. If you are going to use a puller, keep in mind if the flywheel does not move easily with it you could still damage the crank.
Striking the flywheel from the side toward the front of the engine with the handle of a soft handled screw driver seems to work the best for me. Light strikes, spin the flywheel around to even it out and it pops right off.
Also I would suggest getting a pair of vise grips or channel locks that are big enough that you can grip the flywheel from it's diameter, not pinching one side of it. You will be able to apply more torque to the nut by doing so and remove the nut easier.
Wes Briscoe is offline   Reply With Quote
Old 05-29-2008, 11:07 AM   #10
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
When I am tightening the flywheel down onto teh collet - will I need to somehow stop the piston/crank from spinning, or is it enough to just the flywheel in place with channel locks/flywheel tool? Ive never done this but Im going to be doing it shortyl and it seems like to tighten the clutch nut down onto teh flywheel I would need to keep the crack from spinning - if so how do I do this?
wstuart is offline   Reply With Quote
Old 05-29-2008, 11:20 AM   #11
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
How could you break a crankshaft with a flywheel puller? I could see someone damaging the front tip of the crank, but thats if the puller has a mushroomed tip or no screw is installed for it to push off of.
Only other way I have removed a flywheel without a puller is to place the engine with the crank tip on a wood block and tap the back of the flywheel with a brass drift punch.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-29-2008, 11:22 AM   #12
ezveedub's Avatar
When you get the nut all the way down on the flywheel, it should hold enough for you to just hold the flywheel and tighten the nut.
Old 05-29-2008, 11:41 AM   #13
jkas10's Avatar
Trader Rating: 121 (100%+)
Is anyone using a special tool to hold or remove the losi 8ight flywheel?
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 05-29-2008, 12:03 PM   #14
golferdude1971's Avatar
Trader Rating: 18 (100%+)
OS Engines has a crankshaft clamp speciality tool that locks the con rod in place when you are trying the remove the flywheel nut and flywheel. OS Part#OSM71530200
http://www.advantagehobby.com/?cat=653
golferdude1971 is offline   Reply With Quote
Old 05-29-2008, 12:23 PM   #15
pinky2252s's Avatar
i thought about that, and i went to grab my bigger ones.. but the sprig was broken so i just did that
Team Terribles
ESC Guide SteveR1960 Electric Off-Road 3 09-19-2007 07:49 PM
I need help removing flywheel slideforlife Nitro Off-Road 3 07-28-2007 10:31 AM
removing a flywheel. help plz? downunder23 Electric Off-Road 2 08-27-2006 01:07 AM
Set Up Guide e_lm_70 Electric On-Road 1 09-12-2005 08:38 AM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 10:54 PM
