Old 05-30-2008, 07:41 AM   #16
TTR:EB4's Avatar
i could have used this a couple of weeks ago (guide that is) but anywayz finally got it off. lol
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 05-30-2008, 07:30 PM   #17
emulberry's Avatar
i bought a Battery terminal puller from auto zone and it is essentially the same as a flywheel puller but costs only about $5
www.NobodyLikesOnions.com
Check it out, edgy, hilarious internet radio, FOR FREE
Associated: TC5 FT w/GTB/13.5
Xray: T1 FK05 w/GT7, CO27
Tamiya: F103GT w/ Cyclone 2
HPI: RS4 PRO 2 (semi-retired)
CEN: Matrix 1/8 scale buggy
S&N Trackside RC
emulberry is offline   Reply With Quote
Old 05-30-2008, 08:15 PM   #18
xlgraphicspro's Avatar
Really? you got pictures of what it looks like?
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-30-2008, 09:32 PM   #19
Cog
Cog is offline   Reply With Quote
Old 05-30-2008, 09:38 PM   #20
Cog
I have changed many flywheels using the clamp I posted. Never had one little problem.
I would not recomending hitting, tapping, wrenching with pliers or forcing a flywheel off. You not only take a chance of screwing up the outer shaft of the crank you also take a chance of screwing up the racer on your front engine bearing.
I haven't a clue of how someone could screw up a crankshaft using a tool that was invented to take objects off of a shaft.
For those of you that do not have the proper wrench that wraps or fits onto the posts of the flywheel, get one, they are cheap and save you time , headaches , energy and in the long run $$$$$$$$$$$$$$$$
If you can gently" tap " your flywheel off the collet with the handle of of a screw driver you either
A did not have it tight enough to start with
B the wrong size collet for that particular flywheel.
They do come in various sizes folks for the people that did not know that and for the most part, each manufacturers Flywheel is a little different size. Some are almost identical but others are like day and night on the size collet needed. Good luck and happy racing.
ESC Guide SteveR1960 Electric Off-Road 3 09-19-2007 07:49 PM
I need help removing flywheel slideforlife Nitro Off-Road 3 07-28-2007 10:31 AM
removing a flywheel. help plz? downunder23 Electric Off-Road 2 08-27-2006 01:07 AM
Set Up Guide e_lm_70 Electric On-Road 1 09-12-2005 08:38 AM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 10:54 PM
