Old 05-26-2008, 04:53 PM   #1
Questions?? Flush New Engine Out?
Do you guys flush your new engines out with fuel to remove any particles from manufacturing?
One site I read recommended this and I don't really feel like doing it, since it's already put together so nicely.
1st- Partially disassemble the engine, at least remove the head and backplate to inspect the inside for shavings, flashing or debris. Flush it out good with some old fuel to get any fine metallic dust particles left over from the machining process, out of the engine. You would be surprised at how much metallic dust can be flushed out of a new engine, do the flush in an old white cool-whip container and you will see for yourself!
http://www.cooperfuels.com/Break-in.htm
Woof is offline   Reply With Quote
Old 05-26-2008, 05:58 PM   #2
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up Always ... Always ... ALWAYS!
I have seen junk in several high end MFG engines. It is amazing how they think this is good for business. I always clean mine whether it be for me or my customers.
Check the deck height too.
TEX
tex1 is offline   Reply With Quote
Old 05-26-2008, 06:00 PM   #3
buckeye34's Avatar
i ALWAYS take the head and backplate off to inspect it. i've used WD40 to
"rinse" the engine,but have not tried fuel.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 05-26-2008, 06:07 PM   #4
mugenb46's Avatar
when i get new engines in if they are going to stay stock i will take a Q tip and use it to clean the inside of the motor, flushing inword could get trach into the bearing or bearings, the fuel while running the motor will go out the exaust, the piston will shedd flakes as well, but using a Q tip can get more out than you think, also pull the HSN out, this way you can flush and alum debree out of the housing, and then put in some after run oil and fire it up.
Important, always lube the motor after a clean up or tear down so you don't have a dry start. good luck
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 05-26-2008, 06:08 PM   #5
Trader Rating: 36 (100%+)
I check every engine I get before use whether new or used. The 20 minutes spent on an engine is worth it given the cost of fixing a premature failure.
rstnboy is offline   Reply With Quote
Old 05-26-2008, 06:15 PM   #6
mugenb46's Avatar
Brian Carey
Pro Twister Mods
615-838-5373
Old 05-26-2008, 06:23 PM   #7
HulkNT1's Avatar
Guys I have never taken an engine apart is there any tips I can get from you guys on the correct way to do this??
HulkNT1 is offline   Reply With Quote
Old 05-26-2008, 06:25 PM   #8
SteveJa's Avatar
Trader Rating: 17 (100%+)
TEX
what do you set your .21 at for deck height ?
.024 ~.025 ??
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 05-26-2008, 06:36 PM   #9
tex1's Avatar
Thumbs up
For 20% fuel I run my engines at .023" to .025". For 30% I run .025" to .027".
TEX
Old 05-26-2008, 07:57 PM   #10
UN4RACING's Avatar
Trader Rating: 22 (100%+)
New one on me what do you mean by deck height?
UN4RACING is offline   Reply With Quote
Old 05-26-2008, 08:00 PM   #11
Integra's Avatar
its the distance between the head button and the actual piston...Head clearance/deck height....w/e u wnna call it....it vary's from motor to motor and fuel to fuel...also pending on your altitude head shimming can come into play aswell.
Old 05-26-2008, 08:03 PM   #12
UN4RACING's Avatar
After its broke in? Is that how you check it?
Old 05-26-2008, 08:11 PM   #13
SteveJa's Avatar
you can check it both ways..... and or you want to know before you run it....
also on the 30% at .025 ~ .027 that goes for most motors ? I ask because I have a go7port that was at .037 out of the box.... and thought that was high (because like you I check mine and run about .025 on all my motors)
so I have another thread "not your normal motor question" and have some pictures of the internals of my go7port with some build up on them.... and was wondering if the deck height could cause that ? or if it is the fuel?
HATCHER RACING !!!!
Impulse R/C
Old 05-26-2008, 10:44 PM   #14
tex1's Avatar
Red face
I'll take a look.
I do check my deck height on all of my motors. .037" is way too high.
Check your other thread.
TEX
Old 05-27-2008, 12:13 PM   #15
Ok thanks, I'm going to clean it out then.
I'll try q-tips, sounds like a good idea.
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 02:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 04:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 03:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
