Old 05-26-2008, 11:22 AM   #1
Default HELP: submerged in water
Hey, I know this sounds really stupid but this afternoon at the track my receiver battery died and my XB8 headed straight into the pond behind the track. I took the servos and receiver out immidiatly and replaced the receiver, I rinsed the tank and motor with fresh nitro, blew everything out with compressed air, coated with wd-40 then blew it off with compressed air, and rebuilt the shocks. I oulled the motor apart and dried it off then re oiled the bearings and rinsed the piston and sleeve with nitro. If you guys have any other ideas as to what I should do let me hear them.
Mike
millsey is offline   Reply With Quote
Old 05-26-2008, 11:27 AM   #2
Nik
Nik's Avatar
sounds like you have it pretty much down...
I can ride my bike with no handlebars.
Nik is offline   Reply With Quote
Old 05-26-2008, 11:31 AM   #3
ok awesome, do you think the servos will be ok? What about the diffs, there sealed right? Also after rinsing the motor with nitro will it be ok?
Old 05-26-2008, 11:38 AM   #4
evostyle's Avatar
Trader Rating: 102 (98%+)
Motor should be fine. I would start it up as soon as possible to get some fuel / oil ran thru it. As far as your servo go, I would open the case top and bottom and spray it completely out with electrical contact cleaner. This will dissipate the water and flush any moisture out. DO NOT use the servos until they have had a change to COMPLETELY dry out. Put them in some direct sunlight for at least a few hours if not the whole day.
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 05-26-2008, 11:41 AM   #5
ok, they were only a 590 and 270 combo that needed upgrading anyways....
Old 05-26-2008, 12:35 PM   #6
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
pond next to the track.. wow talk about a bad time to lose a reciever pack!!
jamminnay is offline   Reply With Quote
Old 05-26-2008, 01:22 PM   #7
really though...my heart dropped when I saw it going. Just got it together 2 weeks ago. I needed new servos anyways. Any recommendations for decent high speed high torque servos that are slightly affordable.
Old 05-26-2008, 01:29 PM   #8
bre1979's Avatar
The hitec 645's are good servos i payed 32.99 a piece
bre1979 is offline   Reply With Quote
Old 05-26-2008, 01:29 PM   #9
I looked at those.....I just wish they were faster......
Old 05-26-2008, 01:43 PM   #10
Trader Rating: 19 (100%+)
I run the Hobbico CS-170 "a rebaged Hitec 5955" and a Hobbico CS-160, another rebaged hitec. The 170 is 333oz torque and .15 transit the 160 is 138 torqueand .14 transit. They are plenty fast, now I do run faster servos like .8 transit but they are in 10th scale electric. I bought the servos through Hobbico for $135, to buy them from Hitec it would be more like $175. And Hobbico has the same great warranty as Hitec. I am not shure if they cover WATER hazards though LOL.
malik is offline   Reply With Quote
Old 05-26-2008, 01:51 PM   #11
where do I pick up the Hobbyco servos?
Old 05-26-2008, 02:15 PM   #12
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
you can get them through Tower Hobbies.
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 05-26-2008, 02:32 PM   #13
Default Servos
Hey, try the JR z9100t and z9100s. They are a bit expensive, but fast and strong----$114.99
Cvdiver is offline   Reply With Quote
Old 05-27-2008, 05:27 AM   #14
jamminnay's Avatar
the jr 9100's are very good servos... horizon will also fix them or replace them in an event of a failure.. sorry water damage is not included in warranty!
Old 05-27-2008, 06:57 AM   #15
I wish I could get a servo covered by water damage though. On a high note the motor runs and the diffs were dry. Servos lock to the left though.
water in lrp esc help!! fairlady1288 Radio and Electronics 19 08-29-2008 10:11 AM
Water + Electronics Saxo Boy Electric Off-Road 7 11-21-2005 12:01 PM
Testing the water... Sorcerer001 Northwest Racers 33 11-12-2005 11:02 AM
Water Sanding water based paint? Rowdy Racer Painting, Designs, Graphics and Photography 5 02-02-2004 07:07 PM
Fun in the water Steve R/C Items: For Sale/Trade 27 05-20-2003 03:42 PM
