Old 05-24-2008, 07:02 PM   #1
Default How to check engine pinch?
How much pinch should a two race motor have? best way to know if it's no good?
dragonman is offline   Reply With Quote
Old 05-24-2008, 07:11 PM   #2
HulkNT1's Avatar
If you can turn it easy with your hand it is no good..
HulkNT1 is offline   Reply With Quote
Old 05-24-2008, 07:26 PM   #3
If it will not stay running when up to temp, it is not enough pinch.
It is hard to tell when cold, and the amount of pinch can vary from engine to engine, and also depends on how much oil is in the chamber.
When it is really easy to turn over when cold, it is near the end of its life.
largeorangefont is offline   Reply With Quote
Old 05-25-2008, 12:19 PM   #4
slow coach's Avatar
take engine out hold flywheel and tilt head slightly over if the compression can hold the engine in situ its good, if it falls through "easily" time to get the savings out, or ask someone with a compression gauge
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
how to check if pinch is good on an engine? cd125374 Offroad Nitro Engine Forum 21 05-10-2012 06:21 PM
Engine Tuning/Setup 101 (sealing and pinch test) Kemorc Onroad Nitro Engine Zone 0 06-06-2007 10:37 AM
Engine Pinch way to TIGHT!!! vw_shorty Monster Trucks 4 05-31-2005 03:13 PM
Engine "pinch" Illusion-Lighti Electric Off-Road 20 08-20-2004 09:25 PM
What's the right way to check engine temp? vettespeed Electric Off-Road 2 01-27-2004 03:38 PM
