Old 05-23-2008, 10:06 PM   #1
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default Not your normal engine question ?
what does it mean when your engine has all kinds of charred black stuff on top of the piston, and all around the exhaust port / ports ? looks like carbon build up.
not sure if this is bad, just would like to know what it is and what it means.
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 05-23-2008, 11:06 PM   #2
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
are you running Sidewinder fuel by any chance
pink_sleeve is offline   Reply With Quote
Old 05-24-2008, 02:12 AM   #3
houston's Avatar
Trader Rating: 91 (100%+)
pre ignition , add a head shim . that is if the carbon build up is extremely bad . need pics of the mentioned engine to tell you if its abnormal or not
later,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-24-2008, 03:51 AM   #4
Also could be a sign, that you are running your engine too lean
Taurius is offline   Reply With Quote
Old 05-24-2008, 05:02 AM   #5
newbie2's Avatar
Default carbon
just wonderin why sidewinder fuel was mentioned ? i have been using sildewinder for a couple of years now with no problems. Actuallly i like it and no I don't use any after run oil and never have had a problem
newbie2 is offline   Reply With Quote
Old 05-24-2008, 07:31 AM   #6
itsshemp's Avatar
could be a fuel issue, or a tune issue. I have ran a few different fuels, and some left alot more carbon then others. I recently switch fuels, due to my normal fuel was not available, for a while. I instanly seen that carbon was building up quickly. Although the lubrication quality seemed that it may have been better (due to how "slimey" it felt), I opted to switch fuels again, only after 1 gallon. Now running another brand, and things look pretty sweet.
If running rich all the time, this could be leaving alot of residule stuff behind also?
itsshemp is offline   Reply With Quote
Old 05-24-2008, 09:02 PM   #7
SteveJa's Avatar
ok... It is a go 7port, around 3gallons..... running byrons 30% / 9% with a OD97T plug... motor runs good, I have not had any problems, just do not like what it looks like inside.....
HATCHER RACING !!!!
Impulse R/C
Old 05-24-2008, 09:41 PM   #8
xlgraphicspro's Avatar
Wow, that looks like A$$. have you tried to clean that off? Acetone or something?
Your running byrons Gen 2 right? you dropped down to the lower oil content 9% instead of 11%? How much of that have you run?
could the lower oil content be an issue?
Hopefully they send you another go tech, WINK, WINK!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-24-2008, 09:56 PM   #9
Nik
Nik's Avatar
looks like your running rich.
to clean it off use 00 steel wool for the top of the piston and the head. do not touch the inside of the sleeve with anything but a soft cloth.
I can ride my bike with no handlebars.
Nik is offline   Reply With Quote
Old 05-24-2008, 11:10 PM   #10
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
what type of glow plug r u using
MBX6>>FUTABA>BYRON FUEL>O.S>ProTek>HITEC
and a mask to inhale nitro fumes
Vsfriedmugan is offline   Reply With Quote
Old 05-24-2008, 11:24 PM   #11
SteveJa's Avatar
OD97T
HATCHER RACING !!!!
Impulse R/C
Old 05-25-2008, 07:01 AM   #12
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I would be careful how you clean off that carbon. The head buttons are easy to clean with polish. As for the sleeve, unless the carbon is building up in the ports, I would leave it alone. Maybe clean the outside with polish, but don't go crazy try to make it spotless. Build up is normal and the black carbon will coat the areas where no friction occur, leaving a coating. Any thick layer on the top of the piston usually can be removed generally by using the edge of a piece of hard plastic to scrap it off. Other than that, it should be fine. And don't touch the sides or the inside of the sleeve as you can or will affect the seal and compression of the engine.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-25-2008, 08:00 AM   #13
mremtr's Avatar
By the looks of the internals , it looks like there is a loth of castor oil in the fuel ? I have not seen black carbon like stuff in a very long time(since the early 80's) like that on your sleeve ports ? That stuff is VERY hard to get off so you will be in for a challange for sure! Check your pipe too ,it may have some seroius build up inside it as well .
That engine looks like it has a ton of fuel through it ?
mremtr is offline   Reply With Quote
Old 05-25-2008, 08:00 AM   #14
Steebo's Avatar
Steve,
I'll let you borrow my polish!
Team Associated, Factory Team, Reedy, LRP, Impulse r/c, Upgrade r/c
www.impulse-rc.com
Steebo is offline   Reply With Quote
Old 05-25-2008, 08:28 AM   #15
Integra's Avatar
its the damn byrons fuel...same with Tilted 30(exact same stuff)...leaves a Nasty residue that other Race fuels dont...like OD 30....ive been told that ANY color to the fuel is obviously dye'd and chances are a colored fuel will leave more carbon then say a Clear fuel with No dye....and like ezveedub said...be Very careful as to what u use on the P+S to clean that stuff off.
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
Help Please. Is this normal. Noob question FavreRunner Nitro On-Road 2 02-20-2008 12:22 PM
General .21 engine question as well as one specific to Sportwerks .21 Pro engine Cain Electric Off-Road 0 10-23-2006 10:19 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
