Old 05-25-2008, 06:29 PM   #16
SteveJa's Avatar
Trader Rating: 17 (100%+)
I have not tried to clean it yet.... do I really need to? also like posted above... (well now after today 3 1/2 gallons) motor runs great, no problems....
go 7 port byrons 30% 9% oil, OD 97T plug 3 1/2 gallons.... losi 8 2 carbon, 2 aluminum clutch. I shimmed the head to .65mm or .24in...... (both the same) 053 pipe......
so is this fuel ??? motor problems??? or normal ????
OH YA.... all the oil... that is after-run oil...... that is why it is all wet.... (sorry forgot to state that)
HATCHER RACING !!!!
Impulse R/C
http://www.aphlikshunfingerboards.com/
http://stevejavorsky.zenfolio.com
More and More its BEARDMORE !!!!!!! (Thanks Todd)
SteveJa is offline   Reply With Quote
Old 05-25-2008, 08:34 PM   #17
pserve's Avatar
Any idea what kind of temps you were running with that?
pserve is offline   Reply With Quote
Old 05-25-2008, 08:42 PM   #18
SteveJa's Avatar
temps from 210 ~ 250 over the 3 1/2 gallons of the motor life...
HATCHER RACING !!!!
Impulse R/C
Old 05-26-2008, 04:47 AM   #19
mremtr's Avatar
Been running Byron's for 10+ years now and have NEVER seen that sort of yuck ! I'll snap a few shots of my 21 gallon 421 for you to see , as I am about to change out the crank because the pilot shaft is worn from a bad bearing ealier this season (locked up and spun on the shaft ) This is my favorite engine too. That burnt up looking black stuff may be from your filter oil ?? What are you using ?
mremtr is offline   Reply With Quote
Old 05-26-2008, 05:01 AM   #20
Bet it's the air filter oil. Try the K&N stuff. Thease people don't play with little toys just six figure toys. My 2 cent
The Working Man is offline   Reply With Quote
Old 05-26-2008, 06:28 PM   #21
tonyy's Avatar
Send a message via AIM to tonyy
Default carbon
Chances are you will leave some kind of grit in motor just put the motor back together and run the thing!But next motor change to a different clear fuel if you change now most of the stuff will come loose and mess the sleeve up!
Sponsors:
www.cenracing.com
www.teamParma.com
www.EBmods.com
www.integy.com
www.motorsaver.com
www.arcshobbies.com
www.paintmonsterairbrushing.com
tonyy is offline   Reply With Quote
Old 05-26-2008, 06:43 PM   #22
I too have been wondering about this. Is there any substance to this post? I have been running tilted and have noticed a lot of coloring on all of my internals on my v-spec. I want to switch fuels since I dont like the high caster oil content in this fuel and the build up it leaves. I have been wondering if swtiching fuels now after a gallon will let that come loose. I have a PTM 3 port from Brian that I dont want this to happen to as well.
clarksib is offline   Reply With Quote
Old 05-26-2008, 07:55 PM   #23
Integra's Avatar
ODonnell burns realllly clean...i tried Tilted 30 green for a gallon and it carboned up the piston Real Good...and imo was lacking some bottom end snap that OD has Always had.....also on a side note....when u get a puff of OD in the face u Know its Nitro.....the Tilted dosent seem to have that same Burn........and the tune from 1 to the other is Totally different....so that tells me its something in the fuel....and for the price difference...illl pay a couple extra $$ for the OD from now on.
Old 05-26-2008, 08:19 PM   #24
Matt Howard's Avatar
and what about the time we temped our motors and my GRP was at 210 and your engine was at 280?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-26-2008, 11:06 PM   #25
tex1's Avatar
Send a message via Yahoo to tex1
Red face Ah... OK I see.
Steve,
Make sure your deck height is at approximately .025". Any lower will be hard to tune and any higher will be harder to burn. Hint - Hint - Wink...
If it is harder to burn you end up leaning the fuel out and here you are.
Is this Gen II fuel?
From the looks of those pics it looks like your case is not cooling. Look at your inlet ports on the outside of the sleeve. The only way to do that is to run extremely hot or not burning all of the fuel completely when you are in your exhaust stroke.
Check your exhaust temps against your head temps. Check right on the first corner of your header. Find the hottest reading to compare to what you are reading on the head. You might find a descrepancy there in your readings. Typically, it takes 285 + to burn like that on the exhaust side. This looks alot like the problems guys had when Magnesium heads came out. Their heads were cooling too good while they were killing the inside of their engines.
Let us know what you find.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 05-27-2008, 05:19 AM   #26
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i have been running byrons for a good while now and have had zero problems with it
jamminnay is offline   Reply With Quote
Old 05-27-2008, 06:19 AM   #27
Vigilante212's Avatar
Wow that is ugly, my lrp 28 with 4 gallons of blue thunder looked 10x cleaner . and I overheated that beast multiple times.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 05-27-2008, 07:58 AM   #28
xlgraphicspro's Avatar
Matt Howard, always call'n someones bluff.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-27-2008, 08:17 AM   #29
rossoh10's Avatar
I have a GO 5 port and it looks the same way......I`m tired o messing with the GO......I`ve had bad luck from the start......I`m going to run my JP Mod v spec for now on.
Oh and I use byrons 30% but not the gen 2
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 05-27-2008, 05:16 PM   #30
SteveJa's Avatar
I hate to say this, but the more I look into this and talk with other people... I think it is the byrons gen2 fuel...... 30%......
anyone else ????
HATCHER RACING !!!!
Impulse R/C
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 08:21 AM
Help Please. Is this normal. Noob question FavreRunner Nitro On-Road 2 02-20-2008 12:22 PM
General .21 engine question as well as one specific to Sportwerks .21 Pro engine Cain Electric Off-Road 0 10-23-2006 10:19 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
