Old 05-21-2008, 09:54 PM   #1
Default How do you remove flywheel?
Hi Guys,
I'm a nitro noob, trying to transplant an engine from some ktm buggy into an 8t. The flywheel from the buggy is too big, so I'm trying to take it off but its very stuck. It looks like a press fit, is there any tricks to taking these things off? Or do I need some tool?
Thanks,
-Jon
deskwarmer is offline   Reply With Quote
Old 05-21-2008, 09:59 PM   #2
Steve Walters's Avatar
Here you go....
Or get a flywheel puller...
Here is one of many to pick from...
http://www.amainhobbies.com/product_...oducts_id/4098
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 05-21-2008, 10:03 PM   #3
Dang, I had a feeling I'd need to buy something.... Thanks for the help
Old 05-21-2008, 10:33 PM   #4
Flywheel sitting across the open jaws of a vise, then tap the crank with a hammer.
largeorangefont is offline   Reply With Quote
Old 05-21-2008, 10:50 PM   #5
Trader Rating: 52 (98%+)
Default cheapest way 10 dollors
go to youtube.com look up nitro clutch. small pulley puller fro any hardware store bouth mine ten dollors never had a problem taken of plenty
mixedguy is offline   Reply With Quote
Old 05-22-2008, 12:10 AM   #6
Seven1Four's Avatar
Trader Rating: 41 (100%+)
Nice one Steve!
Go to an auto parts store, get a "battery terminal puller", best $5 spot you'll ever spend!
Allen
STICKY⭐️KICKS | OC_RC RACEWAY
Seven1Four is offline   Reply With Quote
Old 05-22-2008, 06:08 AM   #7
kevinmajor's Avatar
You could try spraying some penetrating oil on the crank shaft at the flywheel. Then put the engine on the side of a table with the crank facing upward and the edge of the flywheel on the table. Heat the flywheel with a heatgun. Then tap on the crank shaft with a hammer, but put something in between the crankshaft and hammer like a piece of wood, so you don't damage the crankshaft when you tap on it. Tap just a couple times, then rotate the flywheel and work your way around it.
kevinmajor is offline   Reply With Quote
Old 05-22-2008, 06:31 AM   #8
speedy2's Avatar
just put a piece of metal tube against the edge of the flywheel
and hit it with a light hammer
it should pop off ...
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 05-22-2008, 06:52 AM   #9
itsshemp's Avatar
I normally can get them off by tapping the flywheel from the backside using the plastic end of a large screwdriver. Tap it, turn it a bit, and tap it some more. Usually pops right off.
itsshemp is offline   Reply With Quote
Old 05-22-2008, 07:28 AM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Those flywheel pullers are one of the most useful tools you can have. It is money well spent if you are gonna stick with this hobby!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
KYOSHO GXR.28 REMOVE FLYWHEEL PROBLEM? aussies1129 Nitro Off-Road 4 08-30-2008 06:39 AM
how do you remove a flywheel from a nitro engine TeamFast Rookie Zone 6 04-26-2008 10:47 PM
HOW DO I REMOVE A FLYWHEEL??? HELP PLZ paul73rc Nitro On-Road 15 06-23-2007 07:33 AM
how to remove nut that attached to flywheel?? bigboss Nitro On-Road 11 10-03-2006 07:42 PM
how do i remove my flywheel? downunder23 Nitro On-Road 5 08-26-2006 03:18 PM
