Old 05-21-2008, 07:39 PM   #1
markus216's Avatar
Send a message via AIM to markus216
Default HELP for Sportwerks Chaos!
Hey i have a Chaos which I bought off of a friend w/ a Picco P-Zero engine in it. and I am having the worst luck w/ it it seems every half tank of fuel i have to replace the front imput gear......I might have had that problem solved cause I put a new one in and put 2 shims in & it worked good.......................for a few minutes Now the spur gear is stripped out. once I replace that I dont want it to happen again to the input OR the spur. Do you guys that have them have any idea of what is making it strip so easily on both and any ideas of what to do to fix it since this is my first nitro car
Thanks from a person in need,
Markus
-Markus Scott
Xray M18 Pro, CRC 3.2R
(MRL)Micro Racing League - www.microracingleague.com
markus216 is offline   Reply With Quote
Old 05-21-2008, 08:21 PM   #2
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Markus
Sounds like the mesh may be to tight. Be sure theres a little gap,or play be tween the teeth and that they are square with each other.
UN4RACING is offline   Reply With Quote
Old 05-21-2008, 08:44 PM   #3
markus216's Avatar
what do you mean "square with each other"
that they are aligned?
-Markus Scott
Old 05-21-2008, 09:13 PM   #4
UN4RACING's Avatar
Yes. If they aren't straight they will wear faster.
Old 05-21-2008, 11:23 PM   #5
markus216's Avatar
this will sound dumb but how would I know if they are aligned.?
just by eye?
-Markus Scott
Old 05-22-2008, 07:47 AM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
just by eye?
It might be a good idea to replace the front bulkhead (the case that the diff assembly goes into.)
Also... you can shim the pinion... but you can also shim the diff side to side to get the mesh right on most cars. Not sure on that one though.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-22-2008, 11:58 AM   #7
markus216's Avatar
Ok......I out one shim on the pinion and two one the "diff side" and that helped to loosen up the gear mesh but I dont want it TOO loose cause that could also strip it out easier.It only takes about 30 seconds of Half speed driving to strip it out
-Markus Scott
Old 05-22-2008, 06:10 PM   #8
Send a message via Yahoo to nitro stan
mine did the same thing with the stock .05
there is no decent diff gears for that car, your stuck with the plastic gears. i had one for about a half gallon, sorry to tell ya.but the best thing i ever did with mine was to trade it for a t maxx
nitro stan is offline   Reply With Quote
Old 05-22-2008, 06:50 PM   #9
markus216's Avatar
I dont have the stock motor in it
-Markus Scott
Old 05-22-2008, 08:11 PM   #10
i know. you have the P zero. im saying that even the stock .05 was enough to trash the diffs
Old 05-22-2008, 08:29 PM   #11
markus216's Avatar
ohh ok
does anyone make metal gears for it even if they arent exactly the same for it just as long as they would fit
-Markus Scott
Old 05-23-2008, 09:15 PM   #12
no good gears for it.
heres a lot of info on the chaos
http://www.rcuniverse.com/forum/m_42...tm.htm#4224621
Old 05-23-2008, 11:11 PM   #13
markus216's Avatar
ok thanks
-Markus Scott
Old 05-24-2008, 03:19 PM   #14
Trader Rating: 3 (80%+)
Send a message via AIM to chris_smith Send a message via MSN to chris_smith Send a message via Yahoo to chris_smith
mine does the same thing but then again mine is running off of traxxas 33% nitro
chris_smith is offline   Reply With Quote
Old 05-24-2008, 08:04 PM   #15
markus216's Avatar
ohh
ok im using TQ 30%
-Markus Scott
FS/T Sportwerks Chaos. ohmygahitscoby R/C Items: For Sale/Trade 6 08-09-2008 11:17 AM
sportwerks chaos baja.pete R/C Items: Wanted to Buy 3 08-09-2008 12:01 AM
FS--> Sportwerks Chaos RTR--> Like NEW RC10GT69 R/C Items: For Sale/Trade 5 05-01-2008 08:38 PM
FS/FT: Sportwerks Chaos Speedycorvette2 R/C Items: For Sale/Trade 5 04-19-2008 05:41 PM
sportwerks chaos. where to get? cm367700 Nitro Off-Road 2 12-22-2007 07:39 PM
