Old 05-19-2008, 11:54 PM   #1
david94's Avatar
Default os21 V-Spec
hey
does anyone have the os 21 v-spec in a 1/8 truggy
does it have good power for the truggy (hyper st pro)
is there anything to make it better for a hyper st pro
is there anything bad or i anything i should know about
it if i was goin to buy the motor
thanks
david94 is offline   Reply With Quote
Old 05-20-2008, 12:18 AM   #2
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
The Vspec is a perfect buggy/truggy engine. It has plenty of power, great on gas, and super reliable. This past Sunday my two friends and I were at Wolcott Offroad track running our truggies. One had the Vspec Speed in his Kyosho while the other had the standard Vspec in the Losi 8. You definitely can't go wrong with OS engines.
HarKonnenD is offline   Reply With Quote
Old 05-20-2008, 05:01 AM   #3
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
josh karl finished third in truggy at crcrc with a standard vspec in his truggy.
jamminnay is offline   Reply With Quote
Old 05-20-2008, 05:29 AM   #4
the vspec has awesome bottom end power. it makes power from 3,000-40,000rpm which is earlier then alot of other engines. most start at around 4,500rpm.
Its a 3 port with great power. perfect match for a truggy IMO
pracy is offline   Reply With Quote
Old 05-20-2008, 07:31 AM   #5
I had mine in my hyper st. Bad thing was I only got like 4 gallons out of it before the compression went away.
_____________________
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Jammin CRT.5 w/ OS .12 TZP 5
Team Losi 8ight-T w/ Ninja JX .21
stiffler297 is offline   Reply With Quote
Old 05-20-2008, 08:36 AM   #6
losiguy69's Avatar
i am running a v spec in my mugen truggy and love it, i just started tuning it last weekend and i was getting 8 to 9 min a tank only running at 190 to 200,i left the os .28 at home and dont miss it one bit plus i was only getting about 5 min with the .28
also the v spec is so easy to tune you basicly set it and forget it i made one adjustment all day, thats what i like
scott
losiguy69 is offline   Reply With Quote
Old 05-20-2008, 09:50 AM   #7
jamminnay's Avatar
vspecs are very easy to tune.. that is one of the good things about them..
Old 05-20-2008, 10:31 AM   #8
PowerHouse's Avatar
Trader Rating: 66 (100%+)
The V-spec has been a good motor for either application. I have a few modded V-specs out there that push a truggy around like it was a .28 and getting over 10 minutes of run time out of it. We have over 6 gallons on a couple and still going strong. Alot depends on the tune and fuel/oil used in terms of motor life is concerned. Most of the rossi and picco based motors I have done have lasted easily into the 10+ gallon range when taken good care of.
PowerHouse is offline   Reply With Quote
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 06:05 AM
Rubber-Spec /Foam-Spec Armedforces Electric On-Road 5 03-25-2008 10:33 AM
REMINDER ECT SPEC TIRES!!!! Stock buggy and truck! Spec 4wd Poweredbysbc Northwest Racers 28 01-11-2008 04:12 PM
looking for pilot shaft for os21 rz-v99b tone Nitro On-Road 0 10-09-2002 06:51 AM
looking for OS21 crank tone R/C Items: Wanted to Buy 0 10-09-2002 06:39 AM
