Old 05-18-2008, 02:18 PM   #1
Default Losi 8 buggy front clutch bearings????
Hi All,
My losi is destroying the front bearings every 20 mins or so, I have replaced them so often I lost count.
I run standard 4 shoe losi clutch and shim / adjust the clutchbell for endfloat.
Has anyone got any ideas??
Cente diff moving? or anything else common.
Many thanks .
btracing is offline   Reply With Quote
Old 05-18-2008, 07:37 PM   #2
MadRussian's Avatar
Your mesh wrong?
Thrust angle of engine off?
MadRussian is offline   Reply With Quote
Old 05-18-2008, 09:08 PM   #3
+1 make sure your engine is perfectly strait and lined up perfectly so you have good mesh and no binding. The only thing that would blow one so fast would be impropper shimming or a big load placed on the bell once everything is set.
clarksib is offline   Reply With Quote
Old 05-18-2008, 09:20 PM   #4
Trader Rating: 38 (91%+)
Thumbs up clutch bearings
I agree with clarksib here. Check your engine mounts, tighten them, use threadlock, and make sure you have the correct shimming. Excessive load is destroying your bearings. A tweak/flex is causing the prob...
LOSI, AE, Mugen, Kyosho
manynitros is offline   Reply With Quote
Old 05-18-2008, 10:31 PM   #5
DirtyDezPirate's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to DirtyDezPirate
Default clutch bell
Uhmm.. what kind of motor mounts are you running I have a friend that had those problem and I checked it out, the motor wasnt striaght and he didnt have the whole bolts tight enough. Also that the RTR chassis flexs more.. but He has same chassis as I am running (carbon fiber by matrix concepts), he didnt have the engine align straight also 2 peice motor mount is weak, theres little play on it when the chassis flexs around on large jump landing.
So you might want to use more shim on the inner bearing, Thats what i did and I never had problem.. still running same clutch bell bearing, 1 gallons through.
I am just ME!
DirtyDezPirate is offline   Reply With Quote
Old 05-18-2008, 10:56 PM   #6
captain america's Avatar
Just out of curiosity, are you running on a track with lots of large jumps? What are your driving skills like? A few off-point landings could be sufficient to cause enough flex to blow a bearing.
Sometimes it's a mechanical problem, sometimes it's the nature of a particular circuit to be harder on the equipment and sometimes it's the driver. A clearer picture is needed for a better diagnosis.
captain america is offline   Reply With Quote
Old 05-19-2008, 08:02 AM   #7
Thanks for the info so far,
Car has a pro chassis and plastic braces, appreciate the info.
How much endfloat do you run on the clutchbell? and also how do you suggest spacing clutchbell, spur gear
Ive read to leave a little bit of play on clutchbell/spur for flex etc but how much is ideal.
I am running with Kingheadz 2 piece engine mount. Tracks vary from small jumps to large but generally nothing huge here in England.
Old 05-19-2008, 08:43 AM   #8
Davidka's Avatar
Trader Rating: 75 (100%+)
Though not very likely your engine's crank shaft could be slightly bent. That would reduce your c/b bearing life by a bunch.
Old 05-19-2008, 11:20 AM   #9
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
it would be unusual to have this problem with the k heands mount... definetly check your crank
jamminnay is offline   Reply With Quote
Old 05-19-2008, 12:22 PM   #10
Integra's Avatar
avid reccomends .4mm for end play...they have a nice tutorial on bearings in general.
http://www.avidrc.com/shop/?action=support
Old 05-19-2008, 02:13 PM   #11
many thanks for the help.
I will set the endfloat at or as near to 0.4 mm
what method is best for the bell/spur mesh, do you use a plain piece of paper to set this or any other. I keep reading that the losi can be set with a little more play in the mesh due to flex on chassis?
If so whats best method for the meshing?
Thankyou.
Old 05-20-2008, 08:35 AM   #12
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Thankyou.
Not "can be." MUST be. The King Headz motor mount that has the "finger" to the gas tank mount helps reduce flex in that area, but you still have to run them a little looser than most buggies.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-20-2008, 12:55 PM   #13
Thanks All,
Brad and others what do you use then to set the mesh more loose,
A single piece of paper between the clutchbell/spur is normal so what do you do to give the more loose as needed.
Thankyou
Old 05-20-2008, 03:12 PM   #14
Trader Rating: 39 (100%+)
Thanks All,
Thankyou
Double the paper thickness.
ridgewaybodies is offline   Reply With Quote
Old 05-22-2008, 06:25 AM   #15
Anyone notice the excess play (lateral) on the front 5X10 bearing? When I spin my clutch bell it doesn't even spin the outer race. I tried another losi 14 and another brand bearing and it was the same. I don't know if this would have any effect on the life of the front bearing, but it doesn't seem right.
spcpicard is offline   Reply With Quote
Losi 8 Buggy clutch question NEMESIS44 Nitro Off-Road 8 05-27-2008 03:05 AM
Losi 8ight clutch shoes/bearings. NEW Xray69 R/C Items: For Sale/Trade 2 05-19-2008 02:38 PM
clutch assembly for losi 8ight rtr buggy playboy Nitro Off-Road 3 12-20-2007 02:41 PM
WTB clutch pins for Losi 8ight buggy!! 8ightTJ R/C Items: Wanted to Buy 0 05-03-2007 06:53 PM
WTB: 1/10 Front buggy tires for losi Johnathan R/C Items: Wanted to Buy 0 04-07-2007 07:18 PM
