Old 05-17-2008, 08:09 PM   #1
Default What hitec servo combo to get? 5955TG and?
Hi all
I tried a lot of searching but could not find any answer for this question..
I am going to order a 5955TG for steering in my MBX5R and wanted to get a digital servo for the trottle/brake as well.
Should i get another 5955TG for the throttle or maybe get a slightly faster servo?
If i got 2 and ever had any problems i could use the throttle servo in my steering and use one of my spares in the throttle which is an advantage.
Maybe a 5996TG which is 105/138oz and .13/.10 compared to
5995TG 249/333oz and .19/.15.
do I need more speed in the throttle then the 5955 get offer?
thankyou
pracy is offline   Reply With Quote
Old 05-17-2008, 08:30 PM   #2
Trader Rating: 19 (100%+)
It is not unheard of to hae the 5955 for both, but I belive it alittle overkill. I use the Hobbico CS-170 which is the 5955 and use a much faster and less powerful throttle. The throttle servo I have is rated at 111 oz of torque and .8 transit time.
malik is offline   Reply With Quote
Old 05-17-2008, 09:58 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
braking takes alot of torque ! min. rule of thumb for me is a minimum of 180in./oz. of torque , speed of .19 or better is plenty fast for throttle
happy motoring ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-17-2008, 10:02 PM   #4
Steve Walters's Avatar
Another 5955TG....................
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 05-18-2008, 06:04 AM   #5
thankyou guys. I just have to find a store with 2 5955's in stock now.
cheers
Old 05-18-2008, 06:37 AM   #6
seayya's Avatar
cheers
Good decision. I have been running the same 2 servos for almost a year now, and I race 2 to 3 weekends each month.
[URL="www.murnanmodified.com"]Murnan Modified Motors[/URL] [URL="www.radiopost.com"]Radiopost[/URL] [URL="www.powermasterfuels.com"]Powermaster Fuels[/URL] [URL="www.agamausa.com"]Agama USA[/URL] [URL="www.hobbyprousa.com"]Hobby Pro USA[/URL] [URL="www.bukupower.com"]BuKu Power[/URL] [URL="www.fastlanegear.com"]Fastlane Graphix[/URL]
seayya is offline   Reply With Quote
Old 05-18-2008, 07:51 AM   #7
tony montana's Avatar
Trader Rating: 65 (100%+)
the 5955 is a beast of a servo, I love mine, but for throttle I would go with the 5996 or 5997, Im running the 5955 for steering and the 5996 in my 8b and yet to have a failure
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 05-18-2008, 09:11 PM   #8
TonysScrews's Avatar
Run two 5955's. The 5955 has a better motor and circuit board (from the 5995 robot servo) so it is more durable than the 5996, 5997 and 5998 servos. If you really need more speed, then get the gear set for the 5997 and stick it in the 5955
Personally, I just run two 5955's in my MBX5R and use a 7.0 volt regulator on a LiPo battery. The 5955 on 7.0 volts is faster than any servo on the market at 6.0 volts and makes over 400 oz's of torque
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 05-25-2008, 01:57 PM   #9
Eccentric's Avatar
Best regards,
How's your reciever handling seven volts? What reciever do you run? I don't wanna cook my JR RS310 or Novak XXTRA...
-Aaron
Dangit, when did all my favorite cars, trucks, airplanes, and engines become "vintage"???
Eccentric is offline   Reply With Quote
Old 05-25-2008, 06:23 PM   #10
Trader Rating: 24 (100%+)
Send a message via AIM to pistolpete
I have used the above with a Futaba Fast and Spectrum receivers with absolutely no problems!!! In my opinion the throttle servos takes more abuse than the steering servo!! It is constantly working and has to stop these heavy cars. The steering servo works less because it's just like a car without power steering. Once you get goin it steers pretty easily. Just my 2 cents.
pistolpete is offline   Reply With Quote
Old 05-26-2008, 05:18 AM   #11
I use two 5955's. www.troybuiltmodels.com should have them.
Aaron
Aaron D. is offline   Reply With Quote
Old 05-26-2008, 07:15 AM   #12
thecman26's Avatar
Trader Rating: 98 (100%+)
Thumbs up
I have had GREAT luck with my combo, 5955 steering and 5965 throttle/brake... It works very well!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-26-2008, 07:46 AM   #13
Sorry, I should have posted what radio system I use. Currently I am running the Nomadio 2.4Ghz React. The Transceivers can handle higher voltages. Before the Nomadio I ran the Airtronics M8 with 2.4 Ghz Spektrum System. The spektrum receivers can also run higher voltages (up to 9.6 volts) so there is no issue.
As for standard receivers such as the Airtronics, Futaba, JR, etc. they only recommend 6.0 volts. So I can't say if they will work on higher voltages.
>>>>>>> BUT keep this in mind. When I used to run a 5-cell 6.0v 2/3A standard hump pack back in the day, they put out much more than 6.0 volts fully charged as well. If I recall, the last time I charged a 5-cell 2/3A hump pack or a 5-cell AA pack the voltage was somewhere around 7.68 volts. So if you limit the LiPo with a 6.5v or 7.0v regulator I'm sure it would work fine with any receiver Disclaimer: I am only making an educated guess so if you decide to do this, it is at your own risk. ....LOL
I'm sure others that run the standard receivers (not Spektrum or Nomadio) will chime in.
Best regards,
Tony P.
Tonys Screws LLC
Old 05-26-2008, 09:26 AM   #14
Eccentric's Avatar
Best regards,
Thanks Tony,
I'm running a Losi 6V regulator. I do hope some guys that run over six volts with standard recievers share their experiences though.
-Aaron
Old 05-26-2008, 10:03 AM   #15
Tree's Avatar
Send a message via ICQ to Tree
I use two Hitec 5955TG servos with a 7 volt regulator from HT Batteries in my TR Arena truggy. The servos are fast and hold strong with the 7 volt regulator.
The best price I have found for the Hitec servos were at Donalds Hobby. You can get the Hitec 5955TG here:
http://www.donalds-hobby.com/prod/sc...dproduct=42427
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
HITEC HS-5955TG Servo tshaec5r R/C Items: For Sale/Trade 8 08-05-2008 12:40 PM
Hitec 5955TG servo work on HPI TF3 Tx? Vrooomvroom Radio and Electronics 2 07-14-2008 04:04 PM
Hitec 5955TG servo! jldjlaudio R/C Items: For Sale/Trade 4 06-09-2008 02:08 PM
Hitec Servo Hs-5955tg bird11223344556 R/C Items: For Sale/Trade 4 05-26-2008 03:30 PM
Hitec HS-5955TG Servo WHOBEE R/C Items: For Sale/Trade 0 11-10-2007 09:09 AM
