Old 05-16-2008, 11:18 AM   #16
air8's Avatar
Originally Posted by ezveedub View Post
The K engines have two relief ports under the exhaust port. The head button is also changed. It runs the same balanced crank though.
Originally Posted by houston View Post
the vertical transfer ports have been switched to the other side of the horizontal transfers , on p5, p5x, p5xs, plus 21-5 the verticals are closest to the exhaust , on 21-5k they are closest to rear main intake with diverters in the block to match . new style thick top ring sleeves to hold pinch at peak performance pinch longer is also another difference .
plus 21-5 is a great engine and if you wanna buy a 7 port piston/sleeve or 421b (821b) p/s set and make it faster you can .
hope this helps ,
monty
I hope this helps. ezveedub and houston answered a couple days ago. Great info and very helpful. thanx again guys.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-16-2008, 04:30 PM   #17
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by novaa View Post
hi Houston,
what is the main different between the plus21-5 and plus 21-5k? plus 21-5k is a newer engine compare to the plus21-5 , but strangely is that how come the plus21-5 is stil more costly.
mind sharing what is the major different between this two engine ?
on the other hand in buggy racing turbo or non-turbo are better?
hope u don't mind sharing your knowledge. thanks
are you talking about on track performance? the differences i noticed (pipe , clutch and plug being the same) between the two is that the k porting design is a little more efficient and a lil more explosive but longer powerband . just takes forever to break the piston/sleeve sets in i am making my favorite engine lately though (hope novarossi starts putting them out too) 421b (821b) p/s/r set in a plus k or plus 21-5 block with turbo button = bookoo power ( hope this helps )
happy motoring ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-17-2008, 12:17 AM   #18
Default erm
that is good elaboration. yeah i guess a turbo button is a better and more explosive on the plus 21-5kt.
thanks alot.
happy motoring ,
monty
novaa is offline   Reply With Quote
Old 05-17-2008, 08:07 PM   #19
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Turbo buttons offer more power though a better seal and combustion chamber, but can be more difficult to tune as they are more sensitive to weather changes. If you order an engine and want a turbo version, order it as such since its cheaper than getting a turbo head after.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-17-2008, 09:03 PM   #20
Default enginess
definitely it will be cheaper to get a turbo engine straight away rather then add in the turbo button later.
by the way any tip in running in engine ?
how do u keep it idle coz usuali after i pluck out the glow heater its just die off and i got to pry the flywheel again.
does loosening of the plug helps?
Old 05-17-2008, 10:01 PM   #21
air8's Avatar
Yes. Plus a heat gun, or hair dryer to warmup the engine case and head first.
--"U Ain't Fast!!"
Chris Pearce
Old 05-17-2008, 10:03 PM   #22
ooooo. a hair dryer. i totally forget bout it. thanks
btw does you guys run it with 5 tanks of 125cc straight without letting it cool down first, or u guy do it run 1 tank then let the engine cool down and start it again ?
Old 05-17-2008, 10:14 PM   #23
air8's Avatar
That's a good question. I think as long as you get heat in the motor so the metals "seat in", then let it cool down a bit, but then get heat back in. That should do good for most engines out there. Heat cycling.
A friend told me today about a break in procedure by Drake. Apparently running the engine for 5 tanks straight, trying to not let it stall. He would vary the temp from 120 F up to 200 F by tuning the needles. I'm not sure though as I didn't read about it.
--"U Ain't Fast!!"
Chris Pearce
Old 05-17-2008, 10:25 PM   #24
ezveedub's Avatar
You can heat cycle the first five tanks, then start to run it around rich, but keep the temps up. I always try to get the engines up to 200+F and I usually use a low nitro/high oil fuel. This way, I can lean the engine to keep it running and heat it up, but still keep it oily for the break-in.
Old 05-17-2008, 10:26 PM   #25
wow. Drake use such a run in procedure too. well i think he dont really need to run it in well. he is a sponsor driver.
i believe that we should run it 1 tank and let it cool and start it again.
well i have also heard of a guy running in engine with big tank and he uses a big fan to cool the engine when its still running.
just too many type of running engine.
Old 05-17-2008, 10:31 PM   #26
ezveedub's Avatar
Onroad guys will bench the engine WOT for a few tanks, then run it.
Old 05-18-2008, 06:58 AM   #27
yeah i guess on road engine is not so time consuming. just 1 or 2 tank and straight to the track and start leaning it down.
Old 05-20-2008, 03:28 AM   #28
I have a stock P5XS for my buggy and a RB mods P5X for my truggy. Any suggestions on Pipes and glow plugs? I run 30% sidewinder and JP-1-2-3`s on my other stuff?
RYAN MCKAY
Owner / Operator of The BarnYard. 1/5 outdoor, 1/8 out/indoor, 1/10 indoor.
teamcracing.net
sweepracingusa.com
smc-racing.net
fuzz86 is offline   Reply With Quote
Old 05-21-2008, 10:19 PM   #29
air8's Avatar
There's NO WAY I'm going to try to mod a sleeve so this is just an off-topic question I guess--What effects will raising the roof of the exhaust port do?
--"U Ain't Fast!!"
Chris Pearce
Old 05-30-2008, 01:32 AM   #30
air8's Avatar
Okaaaaay. Had a look a the selection of Novarossi plugs. Yikes. So I guess I'll start with this question:
What are the differences between a #4,5,6,7,8 plug. All of them can come in standard plugs. Uhhhhhh....NEVERMIND. Geez, it pays to use the filters when searching online.
#4--Very Hot
#5--Hot
#6--Medium
#7--Cold
#8--Very Cold
And then you can select from Heavy Duty or Regular. Sorry guys.
--"U Ain't Fast!!"
Chris Pearce
Novarossi 35 plus21 rcdoktor2 R/C Items: For Sale/Trade 1 07-06-2008 08:52 PM
XB8EC with Novarossi Plus21-5KT HELP! Engine problem. sportssedanman Nitro Off-Road 5 02-21-2008 03:05 AM
EB MOD... NOVAROSSI PLUS21-5... Smoothone R/C Items: For Sale/Trade 2 08-09-2007 04:47 PM
a quick question benraldo the ho Electric On-Road 7 03-29-2004 10:46 AM
Quick question? lazarus Electric On-Road 3 03-17-2004 11:13 AM
