Inferno MP9 thread
#1831
Registered User
#1833
I believe its just going to be a cheaper version of the car we already have. No anodized parts or velvet shocks.
#1835
#1836
TKI=Team Kyosho International, BUT, the current MP9 kit is the TKI version, not the one listed in the link(s) above or on BSI website. The new version is the standard grade version kit without all the HARD treatments and Velvet coatings. Also no wheels or AKA tires are included. Part# is 31783
#1837
#1838
You really dont need the new rear shaft if you shim things right, shim from the inside of the hub.
For added safety if your running on large high jump tracks yes that would be a wise investment.
On my mp9 it popped out at 3 degree toe and camber 1 but at 3 on 5 and proper shimming no issues, use them till they wear out them switch to the new ones.
I would say the only items to consider for the mp9 are the new bushings radio posts and rear wing posts with the if408c diff boxex, other then that have yet to see something on the mp9 to break on abuse.
Always driver errors and not quality subject.
Will be racing at the prefemca and femca race in malaysia and will see what happens there that track got some massive jumps
#1839
http://www.buggy-sport.info/include....ntent/news.php
Guess they realized that the current MP9 we have is in fact the full spec MP9 TKI.
#1841
I helped with developing the upper arms. The plastic bushings are so the allum. was,t riding on the pin. Replacments were offered because, when you take a hard shot to the front and snap a lower arm. the upper arm is allowed to be pushed back way futher than it is intended. sometimes this can smash the inner bushing and cause unwanted movement. 4 gallons on mine and no slop
#1843
Can anyone confirm or deny that the new colored bushing inserts [yellow/green/orange] are out of a harder material than the original gray ones? I read somewhere that this is the case, but found it funny that Kyosho omitted that from all the insert product descriptions.
also, Kyosho does things a little different than most other companys. sometimes information is scarce, but if the part is an update, you can usually bank on it being improved.
The other part that is suggested is the updated front suspension plate. i think if439b "B" being the update. its thicker. i have heard some people say they have bent the original one from a crash.
My car has been reliable for me with the original parts. In 5 or 6 gallons, i had a nut backoff the steering knuckle, cuasing me to not finish a race. but updates can only help, and i'm more than happy they continue to improve the car.
#1845
MO
