Inferno MP9 thread
Has anyone got any experience with the titanium screws for the mp9?
Are they strong enough to be used in all areas of the car?
Regarding weight, what is the closest any of you have gotten the car to the legal weight? Is it easily achieved?
I'm starting to get a bit more serious with my cars now and looking for any advantage I can get mechanically.
Any input would be great thanks
92653H 5.8mm Sway Bar balls hard
IFW416 6.8mm Steering Link balls outer hard
IFW417 6.8mm Steering Link balls inner hard
IF462H 5.8mm Servo link balls hard
IF463H 7.8mm Rear Inner link balls hard
IF464H 6.8mm Front upper arm balls hard
IF465H 7.8mm Rear Outer link balls hard
W0201H 5.8mm Lower sway bar link balls hard
W0204 6.8mm Lower Shock end balls hard
Tires, wheels, and foams affect the overall weight as well and are often forgotten about.
In addition to the stuff Sean mentioned, you can actually go under weight with titanium hinge pins, turnbuckles, additional misc titanium screws from Lunsford (the big 4mm cap head ones that secure the A block, the front shock tower, the wing stay to rear tower, 3mm upper out turnbuckles to hubs, those long 3mm ones that secure the upper rear chassis brace and wing stay, aluminum nuts, titanium lower shock pins, kit chassis ceramic bearings and Radio Post servos. I say RP because that's what I had in my car at the time. KO hard case servo are hEaVIer. This is with the car ready to run including body, no gas in tank.
Last edited by My ST-RR EVO; 11-26-2014 at 12:54 PM. Reason: forgot to mention the ceramic bearings
My M2C Chassis and M2C Motor Mount have a gallon 1/2. I discovered yesterday my clutch bell still hits. Not as violent, but still hits.
If any one needs anything during the Masters please PM me and I will help out as much as I can!
got a question about the front shock tower. i need a new front shock tower(bent). is if477 tower included in new kits or is it still an option.
dollarhobbyz has shock towers claiming to be if477. but are a different colour.
http://www.amain.com/kyosho-inferno-...gy-kit/p253661
http://www.dollarhobbyz.com/kyosho-1...ock-tower.html
dollarhobbyz is cheaper but are they if477.
thanks in advance for replies.
the dh ones are the brown ano ones that come with kits, not the gold hard ano replacement part.
thanks fellas. not really worried about the colour. just need to know if they are the same strength. they look the same just different colour.
will this shock tower fit on a tki3 and is there any thing different to the stock shock tower
http://www.amain.com/kyosho-aluminum...-tower/p229197
@Lochlan/kyosho- that is the replacement tower for the TKI3. It is gold hard anodized (HA). It carries the same part number as is listed in the manual, but the tower that comes in the kit is brn anodized. It is not sold separately by Kyosho. If you need it replaced you have to buy the gold HA tower which is what your link is. The same goes for the anodizing and availability for the front tower, shock bodies and chassis. Someone on here proved, by measuring with calipes, that the HA chassis is a tad thicker than the kit chassis. I'm still using the kit towers and don't know if there is a slight thickness difference in the towers.
@Coneman- Depending on how bent your tower is, you may be able to just bend it back using a vice and a pair of pliers. We ran on blue groove all summer and it was very brutal on the cars. I bent two front towers and bent them both back. I thought they'd be a lot weaker or break on a subsequent crash or bend more frequently, but it's really hasn't been an issue.
No worries Evo. i ended up ordering a tower from dollarhobbyz. i'll try and bend the bent one back so i can race next weekend. won't get the new one in time.
**EDIT**
Please keep your for sale and want to buy items in the correct forums.
**EDIT**
Please keep your for sale items in the correct forums.
