Old 05-12-2008, 08:55 PM   #1
Default engine troubles
my revo with a 3.3 is 2 years old with 2 gallons runs through it. when I fire
it up it stalls right away. every once in awhile it will run on its own for a short
duration until I give it throttle and it chokes itself out. is it flooding itself?
"too rich?". I'm stumped becauase I have gone back too factory settings
and tuned accordingly from there. I can't be that rich because it was
showing signs in the highspeed runs for a leaner mixture. I tried bumping up
the idle just for kicks.(eventually maxxed it out, fuel was puking out of the
exhaust when I gave it throttle) I'm hoping it's something i've missed.
rcbc is offline   Reply With Quote
Old 05-13-2008, 04:36 PM   #2
I have a traxxas nitro rustler it has done the same thing before i turned the high speed needle out 3 turns that is a little lean so be carefull i did that just to get it to run and i turned the low speed out twice
another thing that could be wrong is you glow plug bad
Traxxas Nitro Rustler
Team Losi Aftershock
Hpi Fire Storm 10T
Team losi Mini T
J**h is offline   Reply With Quote
Old 05-13-2008, 05:25 PM   #3
Old fuel??
Pacific Rider is offline   Reply With Quote
Old 05-13-2008, 05:58 PM   #4
It could be old fuel how long have you had it?
Do you put after run oil in you car when you done driving it?
If you donít put after run oil in it the motor it will gather moisture and cause it to rust and if that happens you should buy a new motor.
Hpi Fire Storm 10T
Team losi Mini T
Old 05-13-2008, 10:57 PM   #5
fuel should be good. i've run blue thunder, backyard basher and now traxxas
top fuel all at 20%. although it has been acting funny since i've introduced
it to top fuel. the glow plug is an LC3 hot and the starter shows a green
L.E.D. I pulled out the owners manual and checked for their signs of a lean burn. (clockwise to lean) it states that ; if you have "popping or clattering
sound when decelerating (detonation) " you are too lean. I'll get that while
I'm trying to turn it over once in awhile. Is that detonation?
Old 05-13-2008, 11:08 PM   #6
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
To be honest the bottom end sounds really rich. I would lean the bottom once hour at a time and see what happens. Good luck.
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 05-14-2008, 04:34 PM   #7
you said its been acting funny since you put the top fuel in it so try to go back to the backyard basher
Hpi Fire Storm 10T
Team losi Mini T
Old 05-14-2008, 09:22 PM   #8
I tried the traxxas plug (supposed to be the proper heat range), put some
other fuel in the tank (old fuel) and leaned out the low speed needle a
little. the high speed needle is 1/4 turn leaner than factory settings.
It looks like the fuel is having a hard time getting to the carb even with
a priming. hoses look like they're in good condition. I also bumped the engine
over with my finger on the flywheel. feels like it still takes a bit to roll it past
top dead centre.
Old 05-15-2008, 01:52 PM   #9
take the head off the motor and see if there is a o-ring on it if there isnt it will not run very long
Hpi Fire Storm 10T
Team losi Mini T
engine troubles!! kn0bbyba11 Nitro Off-Road 13 05-23-2008 11:39 PM
Engine troubles jgtruggy Nitro Off-Road 5 03-22-2008 03:39 PM
engine troubles banabits Rookie Zone 2 10-03-2007 09:51 AM
Engine Troubles PLZ HELP!! Hoggy Nitro On-Road 6 06-27-2005 10:43 PM
Engine Troubles! B3boy Electric Off-Road 5 07-12-2002 11:03 AM
