Old 05-18-2008, 09:08 AM   #16
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
whatever u do, get rid of that short body plug! I had a B3 and I used a OD#99.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 05-18-2008, 09:31 AM   #17
Truggy007's Avatar
i'm using werks 30% with great results.
i added 1 extra head shim on both trucks and using hot plugs.
they both idle nice and steady with great power.
8IGHT-T / O.S. V-Spec / O.S. 2050 Pipe
Race REVO 3.3 / EB Mod O.S. 18TM / THS Racing Pipe
Werks 30%
Truggy007 is offline   Reply With Quote
Old 05-18-2008, 11:28 AM   #18
houston's Avatar
Trader Rating: 91 (100%+)
using a short plug is like adding a head shim , just not the best way to add combustion chamber volume use an odonnel 77 or mccoy mc8 and a head shim to your engine !!! the b3 must not be shimmed for running 30% from the factory .
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-18-2008, 11:21 PM   #19
fadedmindz's Avatar
but check it out my biggest problem is now this one
"ok new question.... lol. well i have put in 2 different glow plugs. they are the standard long plugs. they keep burning out! for aparent reason. there is no damage visibly seen to the glow plug so idk what it is. i put an A5 short plug and it has been running fine? what going on????"
.::fAd3dM!NdZ::.
take a look!!! ---> http://www.rctech.net/forum/showthread.php?t=218319&highlight=fadedmindz
TEAM ASSOCIATED RC10T3--> lrp QC2
KYOSHO USA-1--> OS MAX .21 RZ VO1-b
OCM KAOS DT-19:
Go 3 port race spec; WERKS team line b3 PRO; Novarossi 421B
Kyosho MP6-->OS MAX .21 RZ VO1-b
Had:TEAM ASSOCIATED NITRO TC3
SPORTWERKS CHAOS
fadedmindz is offline   Reply With Quote
Old 05-18-2008, 11:22 PM   #20
fadedmindz's Avatar
Thumbs up
thanks guys.
.::fAd3dM!NdZ::.
OCM KAOS DT-19:
SPORTWERKS CHAOS
Old 05-21-2008, 03:54 PM   #21
Viat's Avatar
Trader Rating: 24 (100%+)
Questions??
Hi guys, I have a question about springs:
I used to the measurement of spring stiffness in LBS
Can somebody tell me comparing REVO springs to Integy or XRAY for example, what would the REVO spring let say 4.9 rate be equal to in LBS?
Thanks, Viat
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
Old 05-21-2008, 03:59 PM   #22
fadedmindz's Avatar
Thanks, Viat
damn! i got thread jacked!
.::fAd3dM!NdZ::.
OCM KAOS DT-19:
SPORTWERKS CHAOS
Old 05-22-2008, 07:53 AM   #23
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by blowpopracer View Post
Personally I dont break my engines in with 30%. The way I would do it is break it in with byrons gen 2 20% then finish the gallon of 20% on the track. When the gallon is gone swich to 30%, shim engine and retune. I like the idea of having the higher oil content for the first gallon is why I do it but to be honest who knows if it helps or not? Just my opinion.
Hope this helps.
oh yeah byrons gen 2 is definately the fuel to run if they have it in your area.
Ummmm... nitro content and oil content are unrelated. For example., Sidewinder 30% has 3 different types with different oil content. I run the 30% worlds blend, which I believe is 11%. The Pro Race blend is 10%. There is also a 12% oil version of the 30% nitro Sidewinder.
More oil will (believe it or not) raise the temps. I've had great success with the Sidewinder Worlds Blend 30% with 11% oil... I have 5.5 gallons on my Werks B7 Pro with zero issues.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-22-2008, 07:25 PM   #24
I only run byrons gen 2 which to my knowledge is only available in the race formula so I figured it would be self explanatory. But thanks for explaining the obvious to me.
blowpopracer is offline   Reply With Quote
Old 05-23-2008, 06:48 AM   #25
Trader Rating: 58 (100%+)
I've read to use a hot plug for break in.....Its normal to go through a plug or two during break in.... Use your racing fuel always.... Make for sure you have no air leaks......If its the newer alum carb, be very careful tightening the retainer nut if you do....It will collapse the throat of the carb.....Recheck the head screws for torque now & then...I always pre heat the motor & loosen the plug just a bit to get her going then tighten. I'm breaking in a new B3pro. its VERY tight! Great thread!
Bigcheese is offline   Reply With Quote
Old 05-23-2008, 04:52 PM   #26
COBRARACING's Avatar
Originally Posted by fadedmindz View Post
ok i just started to break in my buggy motor today. i have a werks tl b3. im using a novarossi plug. i think its a #6 i dont remember actually. have to rechec. but anyways what do you guys (b3 owners) recomend to run. im running trinity monster fuel 20% but want to switch out to byron's gen2 once i get it up and running smooth. can anyone help?????
ok more help. i need a glow plug. wanted to be more specific. yea i kno i wanted to get rid of that fuel. i actaully need a plug. i was running a novarossi #6 and it went out. i dont kno how but yea it did. what do you guys recomend as for a glow plug for this motor?
please email me at info@teamcobraracing.info or call me on +61 430009769 and i will explain to you in detail ok .to much to write in this forum as an explanation .
regards ANgelo
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
RC Knowledge base rcpoint Web Links 0 03-26-2008 01:01 AM
Anyone with TC4 knowledge, help Intotheblade Electric On-Road 1 10-22-2007 03:50 PM
RC knowledge sharing catkchun Malaysian R/C Racers 79 10-18-2007 06:31 PM
impress me with your knowledge...please! clueless Rookie Zone 13 07-12-2007 11:03 AM
RC Knowledge Website JBennett Web Links 7 04-27-2005 01:55 PM
