Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-09-2008, 01:34 PM   #1
Unhappy Help with a AXE mamba .21
Hi everybody on the forum this is my first post here and i'm in need of some help, i have a hyper8 pro with a AXE mamba .21 engine, i installed the turbo head. i just have finished the break in but after a 5 or 8 min of running the engine seems to stay accelerated at the point that when i do a jump and relase the throttle the engine keep accelerated all the jump, also when the car is running and i relase the throttle the car keeps going for about 2 seg and make take the turns a bit tricky. the iddle is ok. i checked the low speed needle but if i turn it rich a bit the acceleration feels slugish and i donīt know if l need to lean more, and for the high speed needle i think is ok, the temperature keeps around 260F its always blue smoke coming out the exhaust and if i turn it a 1/8 turn leaner the temp goes to 270 or 280F, so i donīt want to lean it more. The engine performace doesnīt feels right , it has a fine off line acceleration but after that feels a little slugish and sounds like is in the rich side, what should i look for?, i live in venezuela and we have here a very hot climate. any advise will help. thanks guys. iīm running with 20% nitro and a os p7 plug.
grivero is offline   Reply With Quote
Old 05-09-2008, 02:02 PM   #2
KThatcher's Avatar
Sounds like an air leak...could be Bearings,carb, or many other things.. also what shims are u running?
- HB Team Driver - Team Epic/Sirio USA - T_Wraps - Race Prep Hobbies -
Fioroni USA-
KThatcher is offline   Reply With Quote
Old 05-09-2008, 02:07 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
First off, you have the wrong plug. You need a Axe Rossi, Novarossi or RB turbo #5 or #6 glowplug. Second, you may the idle open too much with a too rich LSN. Use the correct plug and try retuning.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 05-09-2008, 02:15 PM   #4
sport10's Avatar
Still sounds like it needs more breakin. It usually takes about a full gallon to break this engine in. The temps will go down once it breaks in fully and the power will come up. This engine really loves the JP3 pipe too. Maybe try the P3 plug instead. The higher the humidity the hotter a plug you will need. On tuning the low speed pinch the fuel line at idle and see how long it take for the engine to change speed. If it is longer the 2 to 3 seconds it is too rich on the low speed.
Losi 8ight
Losi XXX-T MF2
Associated B44
Associated B4
sport10 is offline   Reply With Quote
Old 05-09-2008, 02:16 PM   #5
sport10's Avatar
Yea the Axe or Nova Rossi plugs would be better.
Losi 8ight
Losi XXX-T MF2
Associated B44
Associated B4
Old 05-09-2008, 02:25 PM   #6
What exactly happens to the engine when you open/close the idle needle?
I know the other needles let more/less gas flow, so is the idle with the air or something?
new to rc cars is offline   Reply With Quote
Old 05-09-2008, 03:28 PM   #7
Thumbs up
Thanks for the replies, i have an AXE R6 plug so i will try to put this on and try lean the LSN. I put the original shim than came with the engine, i only take away the original head and put the turbo in. Is it really that hard this engine to break in?, so i would wait for the temp to drop down with every use i put on the engine?, thanks again.
Old 05-09-2008, 04:00 PM   #8
ezveedub's Avatar
You need to leave the shims in.
Old 05-09-2008, 05:28 PM   #9
I check and it has two coopers shims between the crankcase and the turbo head
Old 05-09-2008, 08:44 PM   #10
Trader Rating: 5 (86%+)
YOu might want to try O'Donnel's 77 Plug. Try go back to factory settings.
Just a few Qs;
1. Does your car flameout during more than 1/3 throttle?
2. Does your car bog below 1/3 throttle?
3. What pipe are you using? (sorry if I missed out on this, I was too tempted to hit the reply button! My bad...)
4. How many times have you replaced your plugs? Your average plug life?
I'm speculating that you might be running too lean, and I don't think there's any air leak yet. Of course I could be wrong about this....
razor_clawzz is offline   Reply With Quote
Old 05-09-2008, 08:47 PM   #11
The idle gap coresponds to your LSN setting, and of course, basically lets your engine run at minimum RPM without dying out or engaging the clutch
Old 05-10-2008, 04:34 PM   #12
Thumbs up
Just a few Qs;
Hi, the car doesnīt flameout, i see blue smoke coming from the exhaust all the time, it sounds like itīs on the rich side but if i give 1/8 leaner the temp goes to +280F but there are still blue smoke comming from the exhaust so i donīt know if itīs safe to stay there, iīm not racing i just want the engine to perform better. the pipe iīm using came with the kit and says efra 2059. i donīt have changed any plug, the engine is brand new it has only about 6 or 7 tanks of use i put the os p7 during the breakin and iīm still using it. thanks for the interest. i feel that it bog below 1/3 throtttle to half throttle.
Old 05-10-2008, 05:10 PM   #13
dont mean to hijack the thread
so it controls gas flow?
my car kind of bogs out when I start it for the first time of the day and accelerate, am I running too rich or what? and I drove 5 or 6 tanks through it in a row with some friends yesterday, in a baseball diamond, so it was WOT like 80% of the time. end temp was only like 170F. im definately running too rich right? and I fooled around with my idle a lot, it wouldnt run, so I turned it like 1 turn, cant remember if it was CC or C, so im also thinking that thats offset.
Old 05-10-2008, 05:13 PM   #14
damn thats hot, mine never goes above 220.
I find that my car bogs out too, It might be my clutch though.
Old 05-10-2008, 08:50 PM   #15
Bro, I think let's ignore the amount of blue smoke rule. Right now if you wanna achieve a certain operating temp, go for that.
Remember, ignore the amount of smoke coming out at the time being.
Try HSN at Flush (3~3 1/2 turns out) and LSN at 4 1/2 out, Idle gap between 0.8~0.6mm. Tune from here, hoping to hear from you soon. Good luck! BTW I think it's best to always keep spare plugs
Hi new to rc cars
This is how I see my things: HSN influences the fuel flow, LSN influences the air flow. Oh yeah, simply put, idle is to allow enough air into the engine to keep it alive.
Please correct me if I'm wrong :S
Forum Jump
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 05:19 PM
Mamba 4200 + Mamba 25 Shawner85 R/C Items: For Sale/Trade 0 01-30-2008 04:54 PM
Mamba 5400 with mamba 25 esc for sale josh the 2nd R/C Items: For Sale/Trade 4 01-14-2007 03:11 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 09:59 AM
Mamba 8000/Mamba 25 esc coolkide R/C Items: For Sale/Trade 11 12-23-2004 04:48 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
