Old 05-09-2008, 05:39 AM   #1
Default Changing pipes?
I plan on getting a 086 pipe for my Go 3 sport. I currently use a JP2, question is, will I have to re-tune or can I just slap it on and go?
Furadi is offline   Reply With Quote
Old 05-09-2008, 06:39 AM   #2
tdeal823's Avatar
Trader Rating: 30 (100%+)
retune.
But it might not be that far off.
I know the JP2 is a top end pipe
I not 100% but isn't the 086 a top end pipe also?
if so the tune might not be that far off.
But in general all pipes make power differently so the tune will also be different
tdeal823 is offline   Reply With Quote
Old 05-09-2008, 08:01 AM   #3
PowerHouse's Avatar
Trader Rating: 66 (100%+)
The JP2 is a bigger volume pipe as compared to the 086. They are both shorter pipes designed more for rpm than torque. The tune will change from one to the other but the 086 should work fine with that motor. The JP2 usually runs a richer setting when comparing it to a smaller volume pipe and you will most likely have to lean the 086 a little to get the performance out of it.
PowerHouse is offline   Reply With Quote
Fuel Changing CREWMAN Nitro Off-Road 5 12-24-2007 03:11 PM
Changing to LIPO wikedgmc R/C Items: For Sale/Trade 4 06-04-2007 09:41 AM
changing xxx-s to xxx-4 {VIC_RDX} Electric Off-Road 6 05-23-2006 08:39 AM
changing power curve using different pipes TC_Tuner Nitro On-Road 0 06-10-2005 03:15 PM
In-line pipes versus old style pipes for .12 engines Hammer0412 Nitro On-Road 25 07-17-2002 11:19 PM
