Old 05-08-2008, 05:28 PM   #1
Default O.S. Help
I have an O.S. .12 CV-X engine in my Hpi NMT. I havent run the thing in like 4 months. I tried to start it up the other day but it wouldnt. I tried and tried and tried. I took the glow plug out and tested it. Its just fine. But idk if i messed up the settings i had before on the carb. Does nitro fuel ever expire? If anyone can help me, thanks so much
MNorthy is offline   Reply With Quote
Old 05-08-2008, 05:35 PM   #2
wes95_z28's Avatar
Yes nitro fuel can go bad after being improperly stored. But i am betting the problem is that you left fuel in the tank or in the fuel lines the last time you ran it. Now that fuel has gelled up in your engine. Remove the motor, disassemble it, thoroughly clean the insides with your cleaner of choice. (Motor spray, nitro cleaner, alcohol) whatever you happen to have. Then remove the fuel tank and use nail polish remover, or laquer thinner and pour some in it. Let it soak over night. Change all your fuel tubing and if you are running one put a new filter on it. Reset the needles to factory settings and you should be good to go again.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 05-08-2008, 05:46 PM   #3
Thanks so much man!
So can i use rubbing alcohol for the engine??
Old 05-08-2008, 06:45 PM   #4
buckeye34's Avatar
Originally Posted by MNorthy View Post
Thanks so much man!
you can, but it may not clean it very well.
mbx5r
v-spec
jp-3 pipe
hitec 5955tg/steering
ko propo 2367/throttle
m-11
buckeye34 is offline   Reply With Quote
Old 05-08-2008, 06:57 PM   #5
do what they said but if still nothing (wont start) you mite need to rebuild it
because OS motors dont last that long.
Jammin CRT.5 ext chassis
Spectrum DX2
OS .12tz (5)
Associated B4 FT
XP digital servo
NOVAK GTX
checkpoint 12x2 modified
ktmusa is offline   Reply With Quote
Old 05-08-2008, 08:10 PM   #6
Alright thanks
Old 05-08-2008, 10:22 PM   #7
wes95_z28's Avatar
The cv-x and cv-r motors are bullet proof. They last forever. If anything goes out in them its usaully the bearings. Now i cant speak for the v-spec or vg series motors but i have heard they dont last long. I have never used one though so i dont know. I have owned a bunch of cv-rs and cv-xs and they are as tough as they come.
Wes
