Old 05-05-2008, 06:02 PM   #1
Revo-lution's Avatar
Trader Rating: 14 (100%+)
Default 17mm hex's and Losi wheels
My 8-T wheels (losi brand, black) seem to have a little play in them from being about 18mm inside the wheel hex on the 17mm truck hex. I've been looking for a solution to snug them up and eliminate the play. I tried some HPI wheels and got the same result.
Any hints on eliminating the play in the hex?
~ Go big or go home ~
~ Novarossi powered 8T 1.0 - A.K.A. 4.0~
Revo-lution is offline   Reply With Quote
Old 05-05-2008, 07:58 PM   #2
I think thats just a problem inherent to Losi wheels.. I know a few people that have stripped the wheel causing the wheel nut to back off and get lost on the track.
I personally will only use pro-line, kyosho or Jconcepts wheels.
Furadi is offline   Reply With Quote
Old 05-05-2008, 11:35 PM   #3
Thats exactly what happened to me with my black proline rims. Maybe mine was because the tires werent tightened properly
new to rc cars is offline   Reply With Quote
Old 05-06-2008, 07:31 AM   #4
Integra's Avatar
my losi wheel's feel pretty tight.....the new LPR's are Rediculously tight on the KH 1/2 off extender's when i run Zero off wheels...1 thing that could also be attributing to the slop ur feeling is the actual hex on the axel....is there any slop between it and the bearing ? Kyosho 8x10 shims in .01mm-.03mm shims will do the trick....just like the clutch bell U have to leave a Tick of play or the bearings will fail pretty fast.
Old 05-06-2008, 11:12 AM   #5
The wheel hex as stated is about 18mm on a 17mm axle hex. To repeat this is also prevalent on my HPI wheels on the same axle hex. You can literally lay it in the wheel and move it slightly. The problem is this makes it impossible to set the toe in and camber since the wheel is moving around on the hex.
On both brands of new wheels I have produce the same result. It's annoying me to death.
Thanks for the comments so far.
WTB LARGE MT WHEELS TIRES & WHEELS 17MM + STIFF REVO SPRINGS jsm11 R/C Items: Wanted to Buy 5 07-18-2008 08:11 PM
Truggy Wheels - 23mm or 17mm? badaml Nitro Off-Road 14 11-18-2007 04:42 AM
wtb: 17mm 1/2" offset MT wheels MattDickson R/C Items: Wanted to Buy 0 10-30-2007 08:09 AM
beat up set of 17mm truggy wheels mjs3350 Other Items: For Sale/Trade or Wanted to Buy 0 05-06-2007 08:19 AM
WTB 14 or 17mm Wheels and tires for Revo Mustang2 R/C Items: Wanted to Buy 13 01-01-2007 08:34 PM
