Lipo receiver pack/regulator question
#16
Guys, if all you need to drop your voltage is by 1 volt install a diode on the hot side of the wire. Radio Shack has a 1N4001 diode for only about a buck and drops the voltage 1 volt (I think it's 1 volt, it'll say on the package). If you need more find a diode rated for higher volt drop. The stripe points towards the receiver if you're doing this.
#17
I don't think, and I could be wrong, that you'd want to run a Rx pack to the point of 3.2 volts per cell. Any less and you risk damage to the Lipo pack. So, get a 2 volt diode and stop running your pack to the edge of failure. Servos & Rx will run on 4.4 volts, not as quickly, but by no means are you close to losing radio contact. But maybe I'm wrong, just some stuff I remember from my EP Heli days...
