Old 12-08-2008, 09:43 PM   #886
jrock32's Avatar
Send a message via MSN to jrock32
I talked to Luther for a while this afternoon about the new parts and when they come out, y'all are gonna dig it! I'm so excited to be affiliated with a company that works so hard to put out a top notch car and continue to develop new parts to make it even better.
Jordan Wilson
O'Donnell Racing Fuel ☆ Hobbico ☆ Futaba/O.S. ☆ TrakPower ☆ Fastlane Graphix ☆ Kal-Gard ☆ Paint by Kiefer Designs ☆ Thank you for the awesome products and support!
jrock32 is offline   Reply With Quote
Old 12-08-2008, 11:57 PM   #887
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
hmmmmm.
first time seeing pics of this cars looks intresting curt i want drive it
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 12-09-2008, 12:02 PM   #888
You would like it prokchop!
You could by 2 of them for the price of the 1 you are running now.
brian kadow is offline   Reply With Quote
Old 12-09-2008, 12:05 PM   #889
porkchop's Avatar
well since i suck at set up i could always ask curt nicly for his
hmmm maybe in 09 when you guys release a light weight car i give it a try
and there no way i you be prying the x2 out my hand love that truck
charles garten
Old 12-09-2008, 01:49 PM   #890
COBRARACING's Avatar
Dear Luther and the Gang
I have been doing alot of research to solve Gears problems with the truggy (out of pitch for meshing) and now i have the procedure to solve this problem.Its been tried and tested.
The procedure is as follows ok read below
STEP 1 when putting the gearbox pinion and crown gear together you must shim the gearbox tight (not loose )what it means is that
when you turn the gearbox outdrives by hand they must be hard to turn so must be tight .
STEP 2 Then place the geabox into the Truggy or use a drill to grab the outdrives or run the truggy for about 1 hour at half throttle to wear in the
the crown gear to the pinion thus becoming a match .
Please Note (Do not run the truggy on the track at full throttle or you risk damage .Full throttle should be exercised when the
gears have been properly run in and the crown and pinion have properly meshed with each other .
it always better to run in your New gearbox before you put it on the track and go balistic
This procedure has been created because it seems the buggy crown gear has been used with the truggy 11 tooth pinion which dont match pitch is not correct.but this procedure seems to fix that problem so you dont blow diffs
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 12-09-2008, 02:47 PM   #891
Chill_Will's Avatar
Trader Rating: 32 (100%+)
BK, I need to give you a shout tonight about something.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 12-10-2008, 05:05 AM   #892
Old 12-10-2008, 06:08 AM   #893
vnmsgt's Avatar
That is very interesting. I wonder if that will work for other brands..... One hour is a long time though but I guess worth it if you know its right.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 12-10-2008, 06:26 AM   #894
Chill_Will's Avatar
Brian I figured it out. I think.
Old 12-10-2008, 06:59 AM   #895
Any questions you can e-mail me at gtbri1773@yahoo.com
Old 12-10-2008, 07:11 AM   #896
Chill_Will's Avatar
So I can't call you?
Old 12-10-2008, 11:39 AM   #897
vr6
Trader Rating: 22 (100%+)
is the truggy available yet, or is it just for elite team drivers still?
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 12-10-2008, 01:30 PM   #898
Chill_Will's Avatar
I don't think the truck is out yet to the public. I was told it will be soon.
Old 12-10-2008, 05:56 PM   #899
bg481's Avatar
hey guys im gettin a sx8 from a friend in a couple of weeks. and i wana know what i should have as spares in case it breaks cause im goin to a big race. please dont leave anything out cause i would hate to break and be stuck with out something since hobby shops dont sell our parts. your help and advice will be greatly appreciated.thank you
bg481 is offline   Reply With Quote
Old 12-10-2008, 09:39 PM   #900
It is worth doing trust me .
there are some things that fail in a gearbox .
1st the shimming must be perfect for pinion and crown gear tight is always better because it will wear itself in.no pinion and crown gear are matches they have to be run in to match .
2nd Gear box cases can also be faulty with not coming together perfectly when screwed tight .
pinion outdrive bearings are also a problem when they of poor quality and can colapse and most kits these days come out with poor cheap bearings.
once a bearing colapses then the pinion detaches off course and thats when the teeth start to break off because of the alignment being off .
shimming is very important .
for example i had a guy break diffs in his nanda nrt-3 but also broke diffs in his kyosho and rc8t and many more so you cannot tell me that the problem is within the product .The problem is with the individual on some occations not all .
I think personally think that if you follow what i have put in place as a procedure then you will not have any problems.
like motors need to be run in so does the drive train its common sense .
not all pinions and crown gears are a match it is impossible you need to match them and the best way is to run them and wear them in .
i hope this helps
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
