Old 11-10-2008, 07:42 AM   #751
Great job TQ Race Team.
brian kadow is offline   Reply With Quote
Old 11-10-2008, 07:47 AM   #752
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Wassup B. If the weather is good we are racing again on the 23rd. I will give you a shout. Some of the Cullman guys are coming and a guy here wants another chance to race you now that he has his own buggy.
Chill_Will is offline   Reply With Quote
Old 11-10-2008, 12:37 PM   #753
I will keep it in mind.
Old 11-11-2008, 03:23 PM   #754
Chill_Will's Avatar
Bama Bump.
Old 11-11-2008, 06:35 PM   #755
vr6
Trader Rating: 22 (100%+)
well i just got my sx8 today and i am very pleased so far at the quality of the plastic and metal parts. i will start building it asap. just thought i would ask about any build specific tips and possibly a setup right now for a high bite indoor track. tires i will run will be panther switches (clay)
thanks in advance for everyones tips and suggestions
vr6 is offline   Reply With Quote
Old 11-12-2008, 04:28 AM   #756
Make sure you put a big washer behind the screw/hinge pin behind the front bumper. If you hit something hard enough it will pull the insert out of the front alum brace. With the washer in place you will never have to worry about it.
I take it Leisure Hours is where you are going to race? That used to be my home track and I am sure the TQ buggy will work awsome there. I would start with 50wt front shock oil and 40wt rear. 5-7-2 in the diffs. Shock oil will be the big thing there. You need the car soft enough for the jumps but not so soft that it traction rolls.
Any other questions feel free to ask.
Brian Kadow
(TQ Race Team)
Old 11-12-2008, 04:34 AM   #757
vnmsgt's Avatar
ahhh so this is where you went VR6! You should like this buggy. It is very nice and very easy to build.
If anybody is looking for a spare I have a SX8 with only 10 tanks on it as a roller for $200 inc. shipping.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 11-12-2008, 08:27 AM   #758
vr6
hey brian, thx for the reply. yes leisure is it, plus newberrys in orion il.
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
Old 11-12-2008, 09:09 AM   #759
Do you have any pictures of your buggy?
TTREB4 is offline   Reply With Quote
Old 11-12-2008, 09:16 AM   #760
vnmsgt's Avatar
I do not have any of it as it sits now with everything out of it. A couple pages back in this thread though are some pics of it. I can get pics but will be probably tomorrow.
Old 11-12-2008, 12:58 PM   #761
jrock32's Avatar
Send a message via MSN to jrock32
Brian K, YGM...
Jordan Wilson
O'Donnell Racing Fuel ☆ Hobbico ☆ Futaba/O.S. ☆ TrakPower ☆ Fastlane Graphix ☆ Kal-Gard ☆ Paint by Kiefer Designs ☆ Thank you for the awesome products and support!
jrock32 is offline   Reply With Quote
Old 11-13-2008, 01:14 AM   #762
When assembling the front C-Hub (4*16 Kingpin screw) that screws into the C- hub, be very very careful not to put loctite on screw, put small amount of loctite on C-Hub thread itself then insert metal sleeve then tighten screw.
If you put loctite on the actual screw then screw it into the C-Hub, when/if it pops out, the C-Hub screw will attach itself to the metal insert, this can become very frustrating, thus you will most likely strip the insert. I learned the hard way and go easy on the locktite
Also you might want to try this posted by the Australian Factory driver I have added a Conical shaped washer either side of the Steering Tie Rod, and also changed the way the steel ball is orientated. This stops the 3*18 screw that holds the tire rods in place from bending as it was happening to me, if you land awkwardly either (L/R) lnose 1st this helps to eliminate the issues.
Hope this of some help, sorry no help to you re set ups
Sorry about my post if it sounds/looks really scattered, I have been up for days studying for uni exams.
Jesussaves is offline   Reply With Quote
Old 11-13-2008, 10:31 AM   #763
vr6
confused by the washer setup location, does anyone else do this and iz there a picture i could see?
i understand the other tip just fine
thanks
Old 11-13-2008, 11:42 AM   #764
I have not felt the need to do that yet.
Old 11-13-2008, 01:45 PM   #765
jaco123's Avatar
Send a message via MSN to jaco123
Hey, i am having the C-Hub issue with the left hand side. I am currently rebuilding my buggy and cleaned/ inspected the Left hub. Put it back together and noticed that its Binding on something, So i looked and had too much lock tight on the screws, so i replaced them with new ones and i am still having the binding issue ( you have to force it alot to turn the hub). The right side works great... Help??
My guess is the Hub is stripped but i could be wrong.
Dalton Oliver
Kyosho mp9 tki3
Xray T4
jaco123 is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
