Old 08-15-2008, 05:24 AM   #451
Trader Rating: 24 (100%+)
Tony , the truck looks good . Please keep us posted on how the truck performs this weekend , Thanks
vino1 is offline   Reply With Quote
Old 08-15-2008, 06:22 AM   #452
Yeti35's Avatar
Originally Posted by Tony Newland View Post
Yeti - dont you have some ride height to check or something?
Nah, my sedans are dialed.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-15-2008, 07:17 AM   #453
Best way to glue the pads to the brake calipers? Sand the caliper a bit then use shoo-goo? What do you guys do?
I have always ran fiber style disks, and didn't like them on my SX8, so going back to metal!
PhillyB is offline   Reply With Quote
Old 08-15-2008, 07:55 AM   #454
Tony Newland's Avatar
Trader Rating: 50 (100%+)
CA
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 08-15-2008, 08:06 PM   #455
moparsrule's Avatar
I'm using the thunder tiger disks and xray pads on mine and it stops on a dime with no brake fade at all.
moparsrule is offline   Reply With Quote
Old 08-15-2008, 08:17 PM   #456
I got some disks somewhere and was using those, they were rubbing the clutch bell. They kept locking up on me (might have been a linkage problem) - and I kept doing stoppies at the end of the straightaway, some kind of annoying.
Old 08-16-2008, 08:54 PM   #457
carlosm's Avatar
Trader Rating: 17 (100%+)
Default Shock Springs
I bought the Kyosho Big Bore shock springs, both FL Green, and Blue for the SX8...becuase the LHS was out of the OFNA BB springs. However I noticed that the Kyosho springs are a little smaller inside diameter than the stock ones and rub on the shock body threads.... Do the OFNA BB springs do this?
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 08-16-2008, 09:41 PM   #458
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
The Kyosho springs fit without rubbing the body. You just have to "click" the spring all the way onto the retainer.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-16-2008, 09:57 PM   #459
carlosm's Avatar
Ahh yes.. the preload adjustment ring! Thank you Joe.
Raced today. The track was blown out andvery rough by the end of my main only my second time out with the car. Did ok 4th in the B-Main, but my first time running in Exp Class. Still not very comfortable with the setup... going out tomorrow to put several tanks through it and work on a good base setup for my self, and just get more familiar with the car...
Carlos Macias
BuckarooGear.com
Old 08-17-2008, 06:53 AM   #460
Trader Rating: 26 (100%+)
Send a message via MSN to BermyDomRepRC Send a message via Yahoo to BermyDomRepRC Send a message via Skype™ to BermyDomRepRC
Hey Tony the truggy looks good cant wait to here your reports on it your doing a great job of keeping people informed here on the net the buggy is looking like its an easy buggy to set up and drive cant wait to read more
keep up the good work guys this will help sales for sure.
BermyDomRepRC is offline   Reply With Quote
Old 08-17-2008, 08:23 AM   #461
Hey guys just got back for the weekend.... the truggy is pretty dialed, I ran 7/10/5 in the diffs and our same 50/40 shock setup with a stiffer spring on a hard and dusty track and liked it alot.... I had fastest lap untill the last round of quals and q'd 2nd for the main. Not bad for not running truggy for almost 2yrs I popped a pressure line off in the main and had to fix it so that put me mid pack somewhere.... but all in all through the initial testing of about half a gallon yestereday the truggy is good.... it accelerates very well, jumps and turns awesome too....
I think we may want to try a longer chassis and a couple of different hubs widths but is 99% ready IMO.
Old 08-17-2008, 01:46 PM   #462
Trader Rating: 19 (100%+)
Billy Easton TQ'd and won the ROAR Region 4 Pro 1/8 scale Championship with his SX8 today at Lake Park, Fl. Buggy looked flawless.
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 08-17-2008, 08:27 PM   #463
carlosm's Avatar
Hey Guys,
Saturday's race was at a new track about an hour away. The track is located in what used to be river bottom area, the dirt being very sandy/loamy. In the beginning heats the track was very fast, but as the day went on heat/lap times starting falling off as the track was starting to get very rutted and blown out. Although fellow drivers and friends said my car looked good out there, I still was not comfortable with the way the car was handling the rough track. So I the morning out at the local track try to establish a better base setup for the car.
My local track is a big open track with sweeping turns and wide lanes. Although the track is big there are a few technical areas and the track is very dry and loose in many areas during non-maintained practice days. There are sections of the track that are rutted and blown out as well. The track also provides ample opportunity to test the cars flawless jumping capabilities. After running several tanks through the car and testing changes one at a time this is what I've come up with. I'm sure as I get more familiar with the car, and travel to different tracks I will change the setup.
My next test for the car will be to experiment with a heavier front diff oil to get the car to pull a little more on power.
Carlos Macias
BuckarooGear.com
Old 08-17-2008, 09:18 PM   #464
jpalessi's Avatar
Hey Guys,
Carlos, Try running less anti squat.. The car seems to like less.. I'm actually working on getting 1* in the car. Billy E ran .5* on a smooth surface,, so that's gotta say something.
Joe Alessi
www.Lucky7RC.com
Old 08-17-2008, 10:12 PM   #465
carlosm's Avatar
Thanks Joe, I will try that too... I thought that smooth track = less anti squat...rought track =more anti squat? Which would make sense why Easton was able to run such a low number on his setup... I heard that track was almost like asphalt. I also know allot of it is one's driving style and most of all skill,and Easton is light years ahead of me.. It's all good stuff though lets keep the info rolling.
Also broke a wing mount today my fault though..Lesson learned use lock tite on the wing adjustment mount bolts.
Carlos Macias
BuckarooGear.com
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
