Old 08-14-2008, 03:44 PM   #436
Local racer's Avatar
Joe is correct our stock wheel is larger then the standard wheel,all the newer wheels work great the older wheels cut into the tierod ends.
Luther
Local racer is offline   Reply With Quote
Old 08-14-2008, 05:07 PM   #437
moparsrule's Avatar
You can use mugen rod ends too, they shouldn't rub.
moparsrule is offline   Reply With Quote
Old 08-14-2008, 05:34 PM   #438
dgraham225's Avatar
Send a message via Skype™ to dgraham225
i have a nanda (almost identical to TQ) buggy for sale if anyone is interested.. its an awesome car, but i wont have the time to race the next few months so im selling off my stuff until i can get back into racing again.. just a lil shameless plug here
getting out of hobby sale!!
Danny Graham
dgraham225 is offline   Reply With Quote
Old 08-14-2008, 06:25 PM   #439
jrock32's Avatar
Send a message via MSN to jrock32
Just got the buggy done! I want to give shout out to Luther, Tony and TQ for putting a top notch buggy together. I was impressed with it right out of the box. I really like the attention to detail and the quality parts. It should prove to be a top of the line buggy. Canít wait to get the truggy. Were rebuilding the track at Dirtburners this weekend and running a Tue night race. Iím anxious to get it out on the track. I've talked to a lot of guys about it and there excited about checking it out too...
Chad B at Fastlane is getting my wraps ready to finish it off!
-Do y'all have any problems with the diff leaking where the grub screw is? I was thinking about screwing it a little past level and filling in with shoe goo. I had it level and sitting on the table when I was putting the car together and it was slightly leaking...
I'll have to get some of the new tie rod ends too and free it up a bit.
Carlos, I thought about doing that with the hinge pins, but didnít want to mess with the bumper. I'll give that a try. I also used the captured hinge pins from my other kit on the upper front arms. Didnít like the e clips. I had to turn those around as wheel so it wouldnít hit the servo saver.
Also, is the stock body pretty durable or would you suggest a jconcepts? If so which one fits the best?
Jordan Wilson
O'Donnell Racing Fuel ☆ Hobbico ☆ Futaba/O.S. ☆ TrakPower ☆ Fastlane Graphix ☆ Kal-Gard ☆ Paint by Kiefer Designs ☆ Thank you for the awesome products and support!
jrock32 is offline   Reply With Quote
Old 08-14-2008, 06:51 PM   #440
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Here you guys go
TQ Racing SX8-truggy-001web.jpg   TQ Racing SX8-truggy-002web.jpg   TQ Racing SX8-truggy-003web.jpg   TQ Racing SX8-truggy-004web.jpg
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 08-14-2008, 07:07 PM   #441
vnmsgt's Avatar
Looks nice but the upper arms seem a little short don't you think. Turnbuckle has alot of thread showing which makes it look like a weak spot.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 08-14-2008, 07:14 PM   #442
To stop the diff screw from leaking I put a bit of the pipe tape (not sure what the real name is but you use it to seal water pipes and air fittings, real thin stringy white stuff - I think its called teflon tape?) on the setscrew and then I covered it with air seal stuff. RTV sealant or high temp silicone from most auto parts stores should work too, I just had air seal already. Mine haven't leaked a drop since I did that.
If you flip the front lower pins around with the nut facing forward how do you get an allen wrench in there? It was painful enough to get them off normally.
PhillyB is offline   Reply With Quote
Old 08-14-2008, 07:34 PM   #443
TonyWest's Avatar
Default vnmsgt
In testing we have not seen a problem.
They thread in far and the turnbuckle is very strong.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 08-14-2008, 08:17 PM   #444
carlosm's Avatar
Trader Rating: 17 (100%+)
Tony - Thanks for the pictures. The Truggy looks good! Are most of the parts on the truggy interchangable with the buggy?
JRock - Good call on the uper hinge pins, I'd like to do that myself.
PhillyB - If you have the front lower hinge pins with the nut side forward, you have to take the front end off to remove them. Which I usally (take the front end off) do everytime I clean the buggy.
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 08-14-2008, 09:23 PM   #445
They thread in along way....... thats also on the outside hole on the hub
Old 08-14-2008, 09:28 PM   #446
vnmsgt's Avatar
Oh ok. I just know some brands do not have that long of threads and they looked like they would not have alot of threads in the arm according to the pics. Cannot wait to see the body painted on it. Also does the truggy and buggy use the same EXACT shocks for front and rear. I have a set of those on my OCM truggy and they fit perfect.
Old 08-14-2008, 09:41 PM   #447
tkcustoms's Avatar
So Tony are we painting that truggy body on the way to the hotel tomorrow?
tkcustoms is offline   Reply With Quote
Old 08-14-2008, 10:10 PM   #448
Yeti35's Avatar
I thought that was just Tony's new paint scheme. Todd, don't beat Tony up too bad this weekend.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-14-2008, 10:16 PM   #449
the shocks are the same
No, got the casper sponsor paint job this weekend.....
Yeti - dont you have some ride height to check or something?
Old 08-15-2008, 05:20 AM   #450
Well for quicker diff access I guess. Shouldn't matter which way they go if you plan on pulling them completely off the buggy, ha.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
