Old 08-12-2008, 12:53 PM   #421
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Move the rear hubs forward and add antisquat
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 08-12-2008, 01:45 PM   #422
carlosm's Avatar
Trader Rating: 17 (100%+)
Thanks Tony. I'll do that and try it this weekends race.
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 08-12-2008, 01:48 PM   #423
Also try to move the shocks out on the rear arms.
brian kadow is offline   Reply With Quote
Old 08-12-2008, 07:48 PM   #424
jrock32's Avatar
Send a message via MSN to jrock32
im putting the big bores together and wondering if im missing a washer...
per the photo, there is an oring, red oring, plastic spacer, red oring and then another washer then the bottom cap. I dont have the washer it shows in the pick before the cap is put on. It does not have a part number either.
when i just put what i have which is the red o ring, plastic spacer and red oring then put the bottom cap on, there is a gap in there...Is that ok? Its not leaking....There is some play in there though.
Jordan Wilson
O'Donnell Racing Fuel ☆ Hobbico ☆ Futaba/O.S. ☆ TrakPower ☆ Fastlane Graphix ☆ Kal-Gard ☆ Paint by Kiefer Designs ☆ Thank you for the awesome products and support!
jrock32 is offline   Reply With Quote
Old 08-12-2008, 08:26 PM   #425
thi is the order of assembly : oring, white washer, oring, black washer.....
the black washer is on the same tree as the bottom spring cups.
pic:
Old 08-12-2008, 08:27 PM   #426
Default washer
jrock32 I answered your question on the grid
2010 Sponsors....BCE Speed, Xtreme Power Systems,
Battlefield R/C, Reino's Ragu Sauce
Garrett McKamie is offline   Reply With Quote
Old 08-12-2008, 08:40 PM   #427
jrock32's Avatar
thanks bro....
Jordan Wilson
Old 08-13-2008, 10:02 PM   #428
Just finished the truggy buildup....
I'll get some pics up tomorrow night
Old 08-13-2008, 10:33 PM   #429
carlosm's Avatar
What offset wheels does the new truggy run?
Carlos Macias
BuckarooGear.com
Old 08-14-2008, 05:40 AM   #430
jrock32's Avatar
The buggy is about 90% done. just need to add elec and motor. I'm impressed with the quality and how easy the build was. Instructions were easy to follow and no TREE'S! I really like how the parts are precut and bagged. only mods I had to make was trimming the lower ark of the servo saver to miss the lower arm bolt and that was it...
Question....I run panther wheels and tires and noticed that they rub on the steering tierod end. anyone else had that problem? i could trim them down a bit, but wonder if that will weaken the strength of the tierod end?
Jordan Wilson
Old 08-14-2008, 06:48 AM   #431
Oh yeah I just looked at mine and they are worn down big time. Not sure what to do about that.
I must have tried 5 different tire/wheel combo's at the yard, ended up using panther tires/green panther inserts/pro-line wheels - all discontinued now, ha.
PhillyB is offline   Reply With Quote
Old 08-14-2008, 08:07 AM   #432
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Standard off set wheels. Truggy comes with +hexs like a mugen or kyosho. I plan on putting a set of the buggy hexs on, and running 1/2' offsets.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-14-2008, 08:41 AM   #433
carlosm's Avatar
Cool, it would be nice to use all the 1/2 offset wheels I already have!
Carlos Macias
BuckarooGear.com
Old 08-14-2008, 09:17 AM   #434
carlosm's Avatar
Mine are worn as well, I run several types of wheels too.
JRock, rather than running my hinge pins that way I relieved the inside of the front bumper so I could run the nuts forward, rather than alter the steering horns.
Carlos Macias
BuckarooGear.com
Old 08-14-2008, 09:23 AM   #435
jpalessi's Avatar
The car was originally designed to only run the BIG wheels..
"LOSI size Wheel"
They have redesigned the rod ends to work with any 1/8 buggy wheel. Order a new set and they should be the updated ones.. If not I had dremaled the original style to work without rubbing. The smaller wheels will rub the top of the C Hub as well, so you may need to trim a lil there too. Or just run the bigger wheels. Good Luck!
Joe Alessi
www.Lucky7RC.com
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
