Old 07-31-2008, 07:17 AM   #346
Trader Rating: 24 (100%+)
Luther , where are those truggy pics at ??
vino1 is offline   Reply With Quote
Old 07-31-2008, 08:51 AM   #347
Local racer's Avatar
Alrighttttt alrightttt this is the proto
Local racer is offline   Reply With Quote
Old 07-31-2008, 09:20 AM   #348
vnmsgt's Avatar
Hey I guys I am putting together my SX8 and came up on one problem so far. I have assembled the steering rack and when I tighten the carbon fiber top plate down on top of it on the side of the servo saver then the steering rack binds and does not move freely. The manual did not show shims or anything, just the bearings, shafts and plastic servo saver. Do I have to shave anything down or something to free it up. I cannot leave the screw loose. Other than that the kit is awesome and goes together really easy! Also found the captured pins after I got the other pins already installed.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 07-31-2008, 09:31 AM   #349
rcejk's Avatar
Trader Rating: 19 (95%+)
Send a message via AIM to rcejk
vnmsgt: i had the same issue when i installed the new hinge pins. when i assembled everything with the e-clip pins everything was free but to free it up with the captured hinge pins you need to either grind down the servo savor where the captured hinge hits it. what i did, i grind down the captured hinge pins thread because its a little longer then needed and ever since then ive had no issues! you could also reverse the captured hinge pin as well by having the hex head facing the servo savor but you would need to dremel out the bumper a little to allow for the nut.
Ethan
Ethan Kovalsky
rcejk is offline   Reply With Quote
Old 07-31-2008, 09:34 AM   #350
vnmsgt's Avatar
Well actually my captured pins are not installed yet. I still have the e-clip pins it it.
Old 07-31-2008, 09:39 AM   #351
rcejk's Avatar
hmm..did you add lock tight? maybe the lock tight ran down on to the bearing? but im not sure..i know someone was talking about how their servo posts were shorter then they were suppose to be? maybe get a measurement of the servo posts and we can get a measurement of one of ours to compare.
Ethan Kovalsky
Old 07-31-2008, 09:43 AM   #352
vnmsgt's Avatar
No loctite yet. When you say get a measurent are you talking about the metal shaft servo post that the bearings slide on? or the Plastic servo post that goes over the metal (part that has the ramps on it) and measure from top to bottom?
Old 07-31-2008, 09:49 AM   #353
rcejk's Avatar
yes, i am talking about the metal shafts that the bearings slide onto along with the servo savor and plastic servo posts.. ha ya you can measure them top to bottom and we can see if their the same length. i believe a page or so back someone had the same issue and they measured theirs and they are slightly shorter then normal.
Ethan Kovalsky
Old 07-31-2008, 09:53 AM   #354
vnmsgt's Avatar
Cool, thanks I will do that now. I have some calipers I will use and let you know.
Old 07-31-2008, 09:57 AM   #355
rcejk's Avatar
awesome! let me know and i'll get those measurements today! also if anyone else has those measurements could you please post them up! thanks
Ethan Kovalsky
Old 07-31-2008, 10:04 AM   #356
vnmsgt's Avatar
My measurement from the bottom face of the shaft that sets on the chassis to the top is 45.61mm. I did notice that is is sitting below the bearing on top and when I tighten the top plate down it is being tightened down on the bearing and not the shaft and looks like the reason it is binding.
Old 07-31-2008, 11:01 AM   #357
You are correct we have address this problem in the new kits,if you put a small washer on the top post it will fix that problem.
Old 07-31-2008, 11:21 AM   #358
Trader Rating: 6 (88%+)
HEY GUYS
heres some new pics of the TQ truggy prototype
TQ Racing SX8-picture-009.jpg   TQ Racing SX8-picture-010.jpg   TQ Racing SX8-picture-011.jpg   TQ Racing SX8-picture-012.jpg   TQ Racing SX8-picture-014.jpg
comming soon MOTORHEAD RC MOTORSPORTS...........
BILL.D is offline   Reply With Quote
Old 07-31-2008, 11:27 AM   #359
carlosm's Avatar
Trader Rating: 17 (100%+)
Looks Sweet! Thanks for posting.
Are we going to be able to run half offset wheels on the new truggy?
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 07-31-2008, 11:49 AM   #360
vnmsgt's Avatar
Looks like it still uses the same buggy front shocks instead of 4 rear shocks. Is this right?
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
