Old 08-11-2009, 11:04 AM   #2161
jzemaxx's Avatar
Originally Posted by Chill_Will View Post
David - Congrats with your overall finish.
ericsp2 - I think Cullman RC Hobbies has one in Alabama. 256-775-2491. They had one the last time I was there racing. They ship parts.
Yup Dan has one on the shelf.
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 08-12-2009, 07:28 PM   #2162
OK team TQ we have the sic race in cull man Alabama indoor event.. who all from TQ are planing to make this event
TTR Racing,NF Hobbies,Proline, WerksRacing,RadioPost,kalgard,I would like to Thank My Sponsors for all the support for 2014
doc6 is offline   Reply With Quote
Old 08-13-2009, 07:38 AM   #2163
There will be a pretty good showing of TQ drivers at the SIC Doc, see ya there.
brian kadow is offline   Reply With Quote
Old 08-16-2009, 04:00 AM   #2164
bump ..
Old 08-17-2009, 04:30 AM   #2165
hairymuffin's Avatar
Trader Rating: 93 (100%+)
do the pistons need to be drilled out?
hairymuffin is offline   Reply With Quote
Old 08-17-2009, 08:03 AM   #2166
Local racer's Avatar
Default What Piston
I don't understand what the question is.
Local racer is offline   Reply With Quote
Old 08-17-2009, 09:46 AM   #2167
Do you guys drill out the shock pistons to a bigger size. I have 35wt losi oil in the rear and it seems to be still too stiff...What is a good starting point?
Old 08-17-2009, 10:22 AM   #2168
35 Losi oil in the rear is a great starting point. Make sure you do not have any binding in your suspention parts.
40wt Losi front
35wt Losi rear
(diffs)
3000 front
5000 center
2000 rear
Old 08-17-2009, 05:02 PM   #2169
RCmayor's Avatar
Send a message via Yahoo to RCmayor
No you don't have to drill the pistons, however I am starting to play with some smaller holed pistons with a little lighter oil.
AE big shock pistons fit perfect and in a pack you get 4 1.3 pistons and 4 pistons with dimples for drilling 6 or 10 holes. Luther mentioned Jammin pistons but they cost over twice as much and they don't have the blanks. If you want to play with pistons I would get 2 packs of AE big pistons and drill away if the 1.3s aren't good.
Here is a little chart I made for total hole area on 6 and 10 hole pistons.
10x1.0mm = 7.857mm2
10x1.1mm = 9.507mm2
6x1.3mm = 7.967mm2
6x1.4mm = 9.240mm2
I am not totally sure on this however the 10 hole pistons at 1.1mm should have similar static feel as 1.4x6 but the smaller holes should have more pack. I am going to play around with this for a while soon.
On another note, I was putting together some new rear shocks last night and when you crank down the seal cap it seemed like the seals were too tight. If this happens, I ended up sanding the little white seal from 1.1mm to 1.0mm. On the black bottom piece I took this from 2.6mm to 2.3mm grinding only the big side which faces the seals. After this I lubed up the seals, re-inserted the shaft, and it was much better.
RCmayor is offline   Reply With Quote
Old 08-17-2009, 05:08 PM   #2170
Are the AE pistons domed or flat?
Panther Tires
Wingtote
RCProduct Designs
92zero Designs
jlog is offline   Reply With Quote
Old 08-17-2009, 05:14 PM   #2171
RCmayor's Avatar
They are flat on both sides.
Old 08-17-2009, 05:16 PM   #2172
RCmayor's Avatar
The new Ghea 10 or 8 angled hole pistons should fit also.
Old 08-17-2009, 05:21 PM   #2173
Are the Jammin flat also? The dome helps channel the oil towards the holes unlike a flat piston works like an umbrella. I guess it depends on the effect you are looking for.
Panther Tires
Wingtote
RCProduct Designs
92zero Designs
Old 08-17-2009, 05:26 PM   #2174
RCmayor's Avatar
I am pretty sure the jammins are flat. It is possible they have both though.
Old 08-17-2009, 05:53 PM   #2175
good info on the shocks.....my son tq'd the open class at the rcpro series west here in socal at revelation raceway this past weekend....ended up second place at the end....car is nice....I have been doin this for a long time and I never ventured out to try an off brand except when I drove for SVM CRONO...But you guys have a really nice car here...good luck to you all. Hope me and my 11 year old can get this car noticed..........
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
