Old 07-23-2009, 10:15 AM   #2101
kamlooper's Avatar
Thanks for the setups guys, could ad a little description of the track to go with? And were you all running the new long chassis?
thanks
kamlooper is online now   Reply With Quote
Old 07-23-2009, 10:29 AM   #2102
That setup that Dave posted is from the nats track and yes he used the long chassis..The track was a blue grooved and hard packed..
TLR|Horizon Hobbies|SpektrumRC|JConcepts|BradleyRacing|92zero|VRP|AceHardware|Tekin|TXDGraphics
CurtDawg is offline   Reply With Quote
Old 07-23-2009, 11:59 AM   #2103
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
This setup will be my new starting setup for anywhere I go, I thought it made the car very easy to drive on a high bite track
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 07-23-2009, 12:09 PM   #2104
kamlooper's Avatar
Thanks guys, I might try that here, med-hi bite + smooth but tight track.
I need that new chasis first
Old 07-23-2009, 01:50 PM   #2105
kamlooper's Avatar
Luther ,pm sent.
Old 07-23-2009, 02:08 PM   #2106
sluggo_sx8's Avatar
Any pic's of the new chasis? how much longer is it over the stock? Thanks for the setup's guys I am going to try them out.
sluggo_sx8 is offline   Reply With Quote
Old 07-24-2009, 05:19 AM   #2107
I believe its 2mm longer then the stock...it moves the weight further back on the rear of the car...Makes the car more stable..
Old 07-24-2009, 06:49 AM   #2108
Chill_Will's Avatar
Trader Rating: 32 (100%+)
A picture won't do you any good. Like David said, it's 2mm longer and hard to tell a difference by looking at a pic.
Is there anything special anyone doing to their throttle servo to make it last or should I just stay away from JR servos.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 07-24-2009, 09:09 AM   #2109
vr6
Trader Rating: 22 (100%+)
ever try the dynamite throttle linkage set? i have used it on everything from a mugen, caster and now my tq sx8
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 07-24-2009, 10:58 AM   #2110
Chill_Will's Avatar
No, I never used it. I may give it a try.
Old 07-26-2009, 04:54 AM   #2111
whiteoffroad03's Avatar
Default Fuquey Varina NC
Went to Cape Fear Raceway near Raleigh NC Saturday. Qualified 5th in the A-Main but unfortunetly the Rain ended the fun before our Main got started. I'm really liking the SX8. I'm starting to get used to the small differences in its driving style vice the Mugen MBX6R I was running.
The only thing I can't find a fix for is the fact that if I land nose down even in the smallest amount off of a medium size or bigger jump, it will dig the nose every time. Has anyone found a cure for this or is it just that critical to land flat or slightly tail first?
Thanks,
Jamie
Semper Fi,
EB Mods
JConcepts
TQ Performance
Competition Products RC
whiteoffroad03 is offline   Reply With Quote
Old 07-26-2009, 06:56 AM   #2112
Do you have the 08 or 09 buggy?
I run 45 wt Losi oil front with full droop
35 wt Losi oil rear
I have never had the problem of the car nose diving off jumps. The only 2 things I could think of would be to thin of shock oil or not enough droop.
Hope this helps
brian kadow is offline   Reply With Quote
Old 07-26-2009, 03:06 PM   #2113
Default nose diving
white offroad-- I have never had this problem before so check:
front droop, I do not run full droop and still have no problems, if you are running alot of droop then loosen the screws out for more ground clearance.
I do run OFNA blue front springs, TQ now has these same springs also. They are a little stiffer so this would help you, and finally be sure you are not running too light of shock fluid. I normally run LOSI weight between 32.5-42.5depending on the track.
Hope this helps, if after these changes it still is happening let us know and we will try something else.
Byron's Fuel,
4C Hobby Supply
Dalton RC Raceway
samos234 is offline   Reply With Quote
Old 07-26-2009, 03:44 PM   #2114
j_blaze14's Avatar
Trader Rating: 34 (100%+)
is it common for the shock piston to shatter with 50wt oil? i have a set of tq shocks in my buggy from another truggy i bought and i cracked the piston in parctice. 4 little chunks floating around in the oil. thanks.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 07-26-2009, 05:12 PM   #2115
Chill_Will's Avatar
J Blaze - I never had that happen. 50wt might be too thick it you have big jumps. I have ran 45wt in the front with no problems.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
