Old 05-31-2009, 01:42 PM   #1906
sluggo_sx8's Avatar
Originally Posted by doc6 View Post
sluggo Your TQ stickers should be there any day now, let me know when you get them....
Sweet thanks I will let you know. Thanks Brian i will try a few things and see what I can come up with. I broke another shock shaft today, have to get it apart and see where it broke but looks like it was right at the threads for the piston. Other then that the buggy worked well today. Still loose in the corners but I think some of that is throtte control hehehe. Anything will be loose in the corners if you are on the gas to hard
I Hope to get the lighter parts soon we will see I guess!
Thanks for all the help guys
sluggo_sx8 is offline   Reply With Quote
Old 05-31-2009, 03:20 PM   #1907
RCmayor's Avatar
Send a message via Yahoo to RCmayor
I was talking to Luther earlier this week and mentioned I was going to try Mugen X5 rear hubs (not X6). I ran the hubs this weekend and they worked very well. Three things the X5 hubs allow are, 1. Longer rear camber link, the outer hole is one hole farther out, the inner hole is the same as the outer hole on the TQ part. 2. The bearing sits about 3mm lower so the axle has a lower angle, 3. The front to back spacing adjustability is increased by about 2mm.
You have to grind 1mm off each side of the outer ball since the mounting space is smaller.
I had some of these laying in my parts box and started comparing the TQ part to the X5 part and thought I would try them, but would like some 2nd opinions.
The wear on the X5 part is better too.
My setup.
Rear
Link, lowest/inner on the tower, outer upper on the X5 hubs, hubs in the bottom hole.
Shocks, Middle upper on the tower, inner on the arm 32.5wt Fusion oil, stock pistons, Silver springs
3.5 Toe, but will probably change to 3, 3 antisquat.
2000 in rear diff
Center 5000, fiberglass brakes.
Front.
Link, Middle on the hub Center on the tower.
20 degrees Caster
4000 diff
Shocks, Center on the tower, outer on the arms. 40wt Fusion,
1 degree toe out per side.
F/R ride ht, 27mm.
Down travel. Chassis on a 40mm wheel, measured from the wheel hex
40mm front, 42mm rear.
Tires, AKA City Block Med(Blue)
RCmayor is offline   Reply With Quote
Old 05-31-2009, 06:39 PM   #1908
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Good run Brian and Doc. Wish I could have came but I had to work. My buggy was good today. It was a little loose but loose is fast and on the edge of out of control. I TQed and won. It was a good day in Bama for TQ. Hope to take it to the Pro Series next weekend.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 06-01-2009, 11:41 AM   #1909
Chill_Will's Avatar
This would make someone a good avatar
Old 06-01-2009, 03:34 PM   #1910
sluggo_sx8's Avatar
Nice Will is that your buggy and what body is that??
Old 06-01-2009, 05:21 PM   #1911
Local racer's Avatar
Great weekend for the Tq Guys Paul Snyder of Mount Joy Pa goes on to TQ and win the Memorial Day Bash at Extreme Rc.
Paul said his Sx8 09 ran flawless all weekend long.
Greensboro native Roy J finished 7th at the 3rd leg of the Carolina points series.
Kevin Donohue of Toronto Canada picked up and SX8 and went out to his first race and finished 2nd saying the car didn't mis a beat all day.
Racers
Local racer is offline   Reply With Quote
Old 06-01-2009, 06:54 PM   #1912
That is my buggy with the pro-line Jamin body.
brian kadow is offline   Reply With Quote
Old 06-01-2009, 06:56 PM   #1913
sluggo_sx8's Avatar
sweet nice looking buggy!
Old 06-02-2009, 08:50 PM   #1914
bump
TTR Racing,NF Hobbies,Proline, WerksRacing,RadioPost,kalgard,I would like to Thank My Sponsors for all the support for 2014
doc6 is offline   Reply With Quote
Old 06-03-2009, 07:02 AM   #1915
Chill_Will's Avatar
Doc, are you racing the Pro Series? I didn't see your name or I might have missed it. Nevermind, I see it.
Old 06-03-2009, 07:13 PM   #1916
RCmayor's Avatar
For bodies, I had a chance to mount up the stock body last week. It fits perfect and looks good. You can't go wrong with it.
Old 06-04-2009, 06:07 AM   #1917
sup chill, i am runing the pro class, , its all good... when you comin down...
Old 06-04-2009, 07:15 AM   #1918
Chill_Will's Avatar
I will be down Friday night. Not in time to practice so I will be at the track early Sat morn.
Old 06-04-2009, 05:27 PM   #1919
Hi guys,
anyone tested the new carbon shock towers?
The front tower does not really look durable.
What is the experience on the track?
______________
Johannes
johnnycash89 is offline   Reply With Quote
Old 06-04-2009, 08:55 PM   #1920
me and Richard will see you early sat morning..got to go threw my buggy and pour lock tight all over it
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 08:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 04:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 10:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 08:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 12:49 PM
