R/C Tech Forums (http://www.rctech.net/forum/)
-   Nitro Off-Road (http://www.rctech.net/forum/nitro-off-road-130/)
-   -   8ight owners, How often do you replace your diff cases? (http://www.rctech.net/forum/nitro-off-road/220175-8ight-owners-how-often-do-you-replace-your-diff-cases.html)
Furadi 05-03-2008 07:37 AM
A buddy of mine that is a Losi freak told me I should inspect and replace my rear diff case after a gallon or two. Said that the cross pins eat into the case. I have about 4 gallons on my 8ight so I pulled it apart and it looked new... Im thinking a lot of it has to do with driving style..
So how often if at all do you guys replace your diff cases?
losi 8 racer 05-03-2008 07:58 AM
hummm
Well it's a tossup,they will start to turn eventually but you can just upgrade to the HD diff's now and save the trouble.
rescuemann 05-03-2008 08:06 AM
I have replaced my diffs to the HD Diffs. The only time that I had a problem is the center diff on my buggy. If your diffs look new, just change the fluid and check for wear on the gears. HD diffs are well worth the money for the upgrade. Good luck dude.
itsshemp 05-03-2008 08:18 AM
I inspect them whenever I change diff fluids. That is about every few races, or if i feel them becoming notchy. I havent eaten too many personally. They seem to last me more than a gallon, but I know people that eat them much more often. I think driving style has lots to do with it also. Just inspect the case, where the spider gear pins ride. If you see them starting to notch, swap them out. Next time I will use the new cases, and that should eliminate the problem.
jgtruggy 05-03-2008 08:30 AM
+1 on the new HEAVY DUTY diffs. They should last a long long time. My back one is the only one I've had to replace.
air8 05-03-2008 10:49 AM
I know this will sound far out there, but i'm at the 15 gallon mark on my buggy and I'm due for replacing the rear diffs on my buggy. The center and front are still new looking. But since the new HD diff are here I'll be putting them in. In the Losi 8ight thread there was talk about different plastic mixtures being used. Seems the first six months the diff were real tough. But the plastic being used after that didn't seem to be a tough. IDK. My diffs are from Nov. 2006 when I first bought the buggy. I started off bashing for a couple months and then went right into racing only.
jgtruggy 05-03-2008 11:03 AM
WOW, 15 gallons? I got about two out of my rear in the 8T. Heavyduty will take care of that:nod:
Nik 05-03-2008 11:37 AM
I bought my car in July of 07 and still use the original diffs.
Furadi 05-03-2008 11:52 AM
Yea, it has to be how people land jumps... ie, if you land with the throttle open its obviously going to be harder on everything.
rezenclowd3 05-03-2008 11:56 AM
You guys are lucky. I haven't used the HD cases yet, but am going to put them in today. I get around ONE race day out of the diffs. I guarantee they are shimmed correctly, as they feel VERY smooth for a gear diff. Usually I have been having to replace 1-2 diffs every race day, VERY rarely all 3. The HD cases will fix this, but the Losi is going to be sold very shortly as my 808 is coming in on Tuesday. I have had my 8ight for a little over a year now.
Furadi 05-03-2008 11:58 AM
:weird: How on earth??
air8 05-03-2008 01:44 PM
I asked the same thing a few months ago. Rezenclowd just has too much power I think. LOL. J/K.
rezenclowd3 05-03-2008 02:12 PM
I asked myself the same questions guys. Believe me, it has frustrated me, but over time I came to accept it. There are a few jumps that it is best to land on power, and it is a high traction track, but still, the diffs should hold up longer than that. In no way do I regret owning the 8ight. I have loved its driving style, the lack of needing to change much when changing tracks, and the ease of maintenance. I know the HD diffs will fix any problems for the new buyer. Back to tearing it down and cleaning it for the new owner....
CarCrazy 05-03-2008 02:54 PM
I got about 1.5-2 gallons on my stock Losi center diff cases before I needed to change them. I would recommend the HD cases for sure. That notching will take you out of a race for sure! If the car feels really loose its time to check them.;)
MaTt 93 05-03-2008 06:22 PM
should i put the hd case on the front diff to or just the centre and the rear
Content © 2001-2011 RCTech.net
