CRT.5 Backplate
CRT.5 Backplate
I am going to put a backplate on the stock Jammin' .12 engine... so, right now, I'm trying to take the pin out of the back... I was told the pin is a 'floating pin' and should be removable.
The pin won't come out easily... is there some trick to getting it out?
Thanks for any help.
Anyone?
what pin might i ask?
The crank pin.
The pin that goes into the pull start. But I'm removing the pull start and trying to put a backplate on.
if the pin is stuck then the spring is over lapping on to the pin you might have to give it a good grip and yank on the pin to get out then pull the spring out with a 1.5mm driver it should slide out.
