Old 05-01-2008, 05:35 PM   #1
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
Default Quick Ace servo question
Anyone running the Ace servos...what's the spline count? I'm planning on ordering one and wanted to pick up an aluminum servo horn, but don't know what it compares to.
Thanks,
David
D Hunt 3 is offline   Reply With Quote
Old 05-01-2008, 05:43 PM   #2
air8's Avatar
Futaba 25 spline is what you need.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-01-2008, 07:31 PM   #3
petevette's Avatar
Send a message via Yahoo to petevette
Yeah, what he said. Ace servos are awesome.
petevette is offline   Reply With Quote
Old 05-01-2008, 08:04 PM   #4
D Hunt 3's Avatar
Thanks guys.
Old 05-01-2008, 10:59 PM   #5
whats a spline?
new to rc cars is offline   Reply With Quote
Old 05-02-2008, 09:21 PM   #6
air8's Avatar
A spline is a shaft that has grooves machined down the length. Almost like a gear, but it's designed into the shaft. So the splines on the servo output shaft must match the splines on the servo horn. This way when the servo turns, it will turn the servo horn also.
--"U Ain't Fast!!"
Chris Pearce
Old 05-02-2008, 10:02 PM   #7
Damn, I wouldnt even bother trying to take apart and fix a servo, id just buy a new one.
And thats the term I was looking for, the servo horn... I have a Hitec servo and the servo horn is smaller than most... I put plastic servo arms on it and it works fine for a few mins, then wears itself out and strips. Or if I hit something that causes force on either one of my front tires, it will instantly strip it!! What kind am I supposed to use? I want a metal one but im not sure what to buy, and should the screw just screw right into the metal arm or does it need a nut at the bottom?
Old 05-02-2008, 10:09 PM   #8
wes95_z28's Avatar
Hitec uses there own servo horn count. I think it is like 23. There all on there own on this. JR, Airtronics, and KO servos all have the same spline count. Futaba and Hitec use a different thread count and aboviously the futaba is a 25 spline but the hitec is something different.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 05-02-2008, 10:24 PM   #9
wow.. -1 for Hitec.
Would this work for me?
https://www.carolinasrc.com/webstore...idproduct=3210
I have a Hitec 625MG
Old 05-02-2008, 11:26 PM   #10
wes95_z28's Avatar
That is what you need.
Wes
Old 05-03-2008, 12:14 AM   #11
Send a message via AIM to CharlieJ Send a message via MSN to CharlieJ Send a message via Yahoo to CharlieJ
Do the rebranded AE servos take the same Futaba 25 spline horns?
CharlieJ is offline   Reply With Quote
Old 05-03-2008, 12:19 AM   #12
wes95_z28's Avatar
I would assume so, but i have never used either brand so i cant be positive.
Wes
Old 05-03-2008, 04:32 AM   #13
air8's Avatar
Yes. They are the same servos as the ACE servos, which are all under the Thunder Tiger name I think. These servos are awesome and very tough.
--"U Ain't Fast!!"
Chris Pearce
Old 05-03-2008, 07:41 AM   #14
jgtruggy's Avatar
Originally Posted by new to rc cars View Post
wow.. -1 for Hitec.
The HITEC 5955 tg dervo is top of the line. Get an aluminum horn and your set. Make sure to set your radio right so you don't blow your servo. The ace1015 is top too. I run the ace for throttle and hitec for steering
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Old 05-03-2008, 08:52 AM   #15
MadRussian's Avatar
Big fan of teh Ace servos here, I run a ds1313 in my 8t and it performs very well and is most concise
MadRussian is offline   Reply With Quote
Quick question...Novak servo NES-1A..... Mabuchi540 Electric On-Road 3 02-27-2016 01:39 PM
Quick question time.....I have a JR Z3550 servo and I'm wondering if it would be.... Mabuchi540 Electric On-Road 6 06-11-2006 05:16 AM
Quick Servo question semore Electric Off-Road 1 01-28-2006 10:32 PM
And todays quick question is.....What Kimbrough servo saver..... Mabuchi540 Electric On-Road 3 07-19-2005 12:22 AM
Quick question? lazarus Electric On-Road 3 03-17-2004 11:13 AM
