Question about 1/8 buggy clutch bell tolerances
I was wondering this. To anyone that has an engine handy with a clutch system mounted on it. If you look at the front of the engine where the crank screw holds the bell on. Can you move the clutch bell any side to side? I know you have the normal clutch bell end play(forward/backwards) play that you adjust with shims, but do you have any side to side play?
I noticed on my losi clutch bells that I can actually move the ends of the bell side to side and see a tiny gap in between the bearing and the inside diameter where the bearings sit at.
Is this normal? Because I have been blowing an awful lot of clutch bell bearings lately and thought maybe this was the cause...?
You are correct in your thinking. A worn out bell can put more side load on the bearings which cause them to fail sooner. Time for a new bell.
I forgot to mention I tried the same clutch setup on a brand new engine and a used one and it did the same thing. So I'm assuming it's a worn out bell. The bell has about 2-3 gallons on it and then I tried the one off my truggy that has about 1 gallon on it and it did the same thing.
Guess it's time for some new bells.......
are your bearing new or ar they old. i would change them first. i have about 2 gallons on my 8b's bell and its fine
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
